Question about ASUS 8.9" Eee 8GB PC Netbook Computer with Windows XP Purple PC Notebook
How to find my cisco connect password? - ASUS 8.9" Eee 8GB PC Netbook Computer with Windows XP Purple PC Notebook
How do I reset my password?
In the below example i'm setting password as cisco for enable mode & Virtual terminals of router
1)Connect to the router and follow the below steps
Router>
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#enable secret cisco
Router(config)#line vty 0 4
Router(config-line)#password cisco
Router(config-line)#login
Router(config-line)#exit
Router#exit
Router con0 is now available
Press RETURN to get started.
Test:
Router>enable
Password: (type cisco to enter into the router privilaged mode)
Router#
Aug 09, 2015 | Computers & Internet
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
Password for guest Cisco connect
For me I am using my laptop and my laptop call Toshiba what can I do make my internet on for good cause it tell me that I have to enter password for Cisco quest access
Aug 18, 2014 | Computers & Internet
Cisco connect
You will need to check the settings on the Cisco connect software.
The Cisco connect software might be installed on your main computer while installing your router.
Read How to find Guest network password
Jun 06, 2012 | Computers & Internet
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about Linksys E1000 cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
Password for guest access
What is the model number of your router? If you have installed the Cisco connect on your main computer then you can find the password for the guest network on Cisco connect software.
You will need to heck the Cisco connect software to find password for the guest network
Dec 08, 2011 | Linksys Computers & Internet
ASUS 8.9" Eee 8GB PC Netbook Computer with Windows XP Purple  PC Notebook Logo
12 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
