Question about Brother DCP 115C All-In-One InkJet Printer
My printer has ink but when printing there is no color
No printing results
4 Suggested Answers
SOURCE: all colored cartridge unable to release ink
my pictures are green no colour. full of ink
Posted on Feb 20, 2008
SOURCE: MFC-440CN printing problem
i cannot print anything
Posted on Jun 03, 2008
  • 61 Answers
SOURCE: PRINTER IS NOT PRINTING COLOR COPIES ANYMORE. INK WELLS FILLED
please check in the printer properties if the print in greyscale option is turned on
Posted on Mar 30, 2010
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
My hp C7180 all in one printer told me I needed to replace an ink cartridge as it would not print in color. I replace the one it said, still did not work, I have replaced all the cartidges and it is still...
First perform an observation of the printers compartibilty to color printing. For example, the printer ought to have been manufactured to capture color pixles to provide resource request in multimedia. usually is possible to have one printer that has several ink location areas to either install color media or dark ink media. In situations where a printer was designed to be black and white ink document compartible would least produce results on color when ink was interchaged. Ascertain that the printer is compartible with multimedia pixel printing proir to acquirng depeltable resources from retail.
Feb 18, 2011 | Office Equipment & Supplies
My printer will print black ink, but when I try to print something with color, nothing appears. I have tried re-installing the color cartridge and restarting the printer. The test page says all ink levels...
I had the same problem. Unfortunately, it may not be fixable. The tiny pipes that carry the ink are REALLY small; about the thickness of a hair. As a result, they can clog. If you only occasionally print in color, the ink in the pipes dries out. You can't do the repair. I was told by the technician that I should print the test pattern occasionally, if I'm not printing in color often.
Jan 16, 2011 | Office Equipment & Supplies
After replacing ink cartridge printer dose not reconize one of six
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Jul 08, 2009 | Office Equipment & Supplies
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Color Printing Problem
Remove all ink cartridges and replace them securely in position.That may be the problem always.
Print nozzle check pattern.See for any missing patterns
Give a head cleaning
Again print nozzle check pattern.If it is ok leave it, other wise give a deep cleaning
  1. If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
  2. Atleast a multi colour( like your visiting card) page should be printed in a week time. other wise the ink may clog in the head.
Mar 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Not printing
The remaining levels of the following ink cannot be correctly detected.
Color
The following ink is running low.
Black [830]
Prepare a new ink cartridge.
The resulting print quality may not be satisfactory, if printing is continued under this condition.
If either black or color ink cartridge has run out, you can set the printer to continue printing with the other cartridge from the Ink Cartridge Settings on the Maintenance tab of the printer driver.
----how to resolve it
email me: akemzone@yahoo.com
Feb 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Sticky photo printing and poor quality
GO IN TO PRINTING PREFERENCES on computer AND CHANGE SETTINGS TO MATCH THE KIND OF PAPER YOU ARE USING OR CHANGE PRINTING PREFERENCES TO PHOTO WHEN PRINTING PHOTOS
Sep 10, 2007 | Dell 924 All-in-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
13 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
