HOW DO I CORRECT THE ERROR FOR DOCUPRINT C1190 FS HAS ERROR 092-310
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Our DocuPrint C1190 FS is only 2 weeks old but
HI
This down to your black of cause cartage, myself if it only 2 weeks old I would go back to the shop and ask them to test it out for themselves, because it may be the heads on the printer that is at fault, some printers have the heads on the ink cartridges and some have them on the inks themselves, if the heads are on the inks then this cartrige could be changed so I would try a new black ink in it first or ask the shop to gave you one in it explace of it you should not be cleaning the heads at this stage of it being 2 weeks old, ask the shop to replace it they will do this for you with no problem, but if you want to try clean it yourself then this what you got to do.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 04, 2010
Testimonial: "Thank you - I will try this tomorrow"
What is error Close C ?
Hi Jim,
I expect it's, "close the cover" referring to the door on the right hand side behind the stacker unit look carefully as it's not always easy to see the problem.
Good Luck.
Aug 17, 2014 | Xerox DocuPrint C2090 FS Laser Printer
Error code c1190 comes up and then asks if we want to continue with out staples and then asks to be turned off.
finisher problem. may be the stapple unit is not in its place. waht sort of finisher do u have (type : FS-XXX) ?
Feb 18, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Scanning to mac
Open System Preferences and make sure your scanner is in your computer under Print and Scan.
Then open up Image Capture and click on your scanner. Then click the scan button, which I have circled in red in the image below.
Mar 02, 2013 | Xerox FX DocuPrint C3290 FS Scanner
FS-1135MFP getting error 2101 when scaning doqument
fs_1135mfp_getting_error_3101_when#solution-heading
Jan 12, 2013 | Kyocera FS-1135MFP
How to reboot printer Xerox DocuPrint C4350 error code : 124-315
How to reboot printer Xerox DocuPrint C4350 error code : 009-383
Oct 24, 2010 | Xerox DocuPrint C4350 Laser Printer
Ive got a xerox docuprint C3290FS that keeps comong up with this scanner sensor error 062-360, is there any way to fix it besides replacing the upper section of the machine? Thnaks.
Ive got a xerox docuprint c3290fs and everytime we fax it comes up with error 035-701 and it takes a couple of goes then it eventually goes through is there any way we can fix this problem?
Oct 13, 2010 | Xerox DocuPrint C3290 Printer
FS C2090 Docuprint - how do you remove the toner cartridges.
here are the documents required for you to resolve the issue
http://www.fujixeroxprinters.com.au/downloads/uploaded/DPC2090FS_Setup-Quick-Reference_en_6f24.pdf
http://www.retrevo.com/support/Xerox-C2090-Printers-manual/id/12396ag121/t/2/
please do not forget to vote for me if this resolves the issue
Mar 24, 2010 | Xerox DocuPrint C2090 FS Laser Printer
Xerox Docuprint 3290FS colour multifunction black overtoning badly then spilling during "calibration", leaving very dark background and blotches of toner cyan overtoning mildly during "calibration",...
Xerox does not list that model at all - are you sure the model number is correct ?
It would appear that either the cartridge or fuser may be defective.
Does the machine show any error codes at all ?
Here is a user manual for a similar model 3225 that may help under the troubleshooting section :
http://www.office.xerox.com/userdoc/N3225/pdfs/UserGuide.pdf
This is where you find manuals for all Xerox products :
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_CA
Oct 28, 2009 | Xerox DocuPrint C3290 Printer
Xerox docuprint C2090 FS fax set up
thanks, had to get a local IT guy out, not sure what he did but all well now
Jan 23, 2009 | Xerox DocuPrint C2090 FS Laser Printer
57 people viewed this question
jasbo
jasbo
