Question about Seiki 47" Class 1080p 60Hz LED HDTV SE47FY19
TV turns on but there is no picture and no sound
TV picture is dark and there is no sound, and when TV normally turns on we see the name and the symbol and sound of tune appears, however tonight no this happens.
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
Turns on dark and then gets lighter
ic circuit is the problem, see TV Tech.
Nov 09, 2013 | RCA F32650 32" TV
Picture brightens then darkens
Trying with a DVD will rule the tuners in the set in or out and also suggest a setting in the set or a box if used is causing this issue.
Nov 03, 2012 | Samsung LN32C350 32 in. TV
Tv turn on no picture
If the sound still works normally but the screen is dark then I would suspect the inverter for having the issue. If you dont have sound either then I would check both the power board and the main board.
Oct 20, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
My tv picture has gone dark
How old is the TV and did you ever have it calibrated?
Nov 20, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony KV-27V36/ No Picture
could be just a fuse or then again if its a plasma the light could be out either way to avoid getting shocked see a tech
Jun 30, 2008 | Sony KV-27V36 27" TV
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Seiki 47" Class 1080p 60Hz LED HDTV SE47FY19 Logo
54 people viewed this question
Top Seiki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Seiki Audio Player and Recorder Expert? Answer questions, earn points and help others
