SOURCE: I have a 2009 ducati
Re-program the keys and this problem on entering the key code on every start will solve:-----------
Follow this procedure :-------
1) YOU NEED BOTH KEYS TO COMPLETE THE BELOW PROCEDURE ------------ This will help.Thanks.Helpmech.
2) Insert Key 1 and hold the UP/DOWN selector to UP and turn the key. Continue
to hold UP until you receive the below output on the display
"00000 PROG"
3) Hold the DOWN selector until the first 0 begins to blink. Type in the code
from your key card and if successful you will see on the display
"PROG ON"
4) At this point, Programming Mode is OPEN and will require you to enter the
code every time to start the bike until you CLOSE programming mode.
5) Once you see "PROG ON",
turn the key off and remove Key 1.
6) Place Key 2 into the slot and let it sit there for 30 seconds without doing
anything.
7) After 30 seconds, hold down the DOWN selector this time and turn Key 2 on
and let the countdown go from 25 --> 1 without interrupting the countdown.
8) Once the countdown is complete, turn Key 2 off and turn it back on. The
countdown will begin again.
9) INTERRUPT the countdown by turning Key 2 off before the countdown finishes.
10) Immediately, remove Key 2 and insert Key 1 and turn on. The countdown will
begin again. INTERRUPT the countdown by turning key 1 off
11) Turn Key 1 On Again.
12) Finished. Upon turning Key 1 on again, PROG OK will appear on the display and
the sync is complete and programming mode is now CLOSED.
