Question about Frigidaire Washing Machines
Why is my washer dripping water in the bottom of the tub?
Fwsr-33f33
  • Frigidaire Master
  • 5,323 Answers
DOES IT DO IT WHEN WASHER IS UNPLUGGED? THEN ITS UR WATER INLET VALVE
Posted on Mar 31, 2015
aborcass
  • 2651 Answers
SOURCE: washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Posted on Feb 25, 2008
  • 177 Answers
SOURCE: Water leaking into tub from inlet
you need to replace the water valve. Look on line for parts for your model
Posted on May 13, 2008
SOURCE: water dripping into tub
One of your water solenoid valves are either going bad or stuck open with a little sediment. Find out which is leaking by turning off one of the water lines to the washer. If after it is turned off it still leaks try turning the first water valve back on the turn the other water valve off. This will help you determine which solenoid valve is having the problem. Once identified it is easily replaced.
Posted on Sep 29, 2008
SOURCE: Leak
Your inlet water valve where the fill hoses attach is stuck open.
Posted on Mar 18, 2009
jackiaria
  • 350 Answers
SOURCE: Fisher and Paykel washer dripping water into tub.
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the highlighted http:// link that follows...
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself! @
http://www.partselect.com/Entry.aspx?
jackiaria
Posted on Mar 21, 2009
Water dripping under the rim, into the tub
Sounds to me like you have a siphoning problem You probably have your drain hose too far down in the drain pipe. When this happens the drain hose goes into the trap of the drain pipe. It then pull the water from the drain pipe back into your washer cause it cant break the vacuum. Pull your drain hose up so that on a little bit of the pipe is sticking down the drain pipe
Aug 25, 2012 | Maytag Washing Machines
Leaking from the bottom of the washer.
it sounds as if the main tub ring is bad you need to pull your agitator out and check the two blots that hold the tub to the shaft and make sure they have not become loose or broken causing the inner tub to drop on the shaft and tear the tub seal.
Feb 23, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Washer leaks out of the bottom. checked drain hose it is not plugged, checked hot and cold water hoses they're ok.
REMOVE THE TOP OF WASHER AND CHECK THE WATER INLET VALVE. I HAVE DONE EVERYTHING AND FINALLY DISMANTLED THE WASHER UNTIL I FOUND THE HOT WATER INLET VALVE WAS LEAKING FROM THE TOP AND DRIPPING DOWN THE TUB AND ENDING UP ON MY FLOOR. IT WILL DRIP EVEN WHEN THE WASHER IS NOT ON DUE TO THE PRESSURE BUILT UP ON THE VALVE.
Oct 25, 2009 | LG WM2688HWM TROMM SteamWasher
Water dripping into the tub. Whirlpool top loading washer
You just need to replace the water vale.
The valve is not closing all the way when its off.
Sep 05, 2009 | Whirlpool Washing Machines
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Leak
Mar 18, 2009 | Washing Machines
Water is leaking from under the washer.
Yes you are correct, there is a seal there. The part is not expensive, but the labor will be. This is a long job.
Mar 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
Washer continues to drip into tub after cycle in complete.
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
