Question about Cycling
Having Creaking Sounds from the Crankset. I have changed BB, Chain, Cassette and it is still noisy. Is it possibly a crack in the frame somewhere near the BB? Sound is prominent especially when standing.
    Scholar:
  • 60 Answers
I can tell that the problem might be the bearing. Try replacing the the bearing.
Cheers!
Posted on Jun 22, 2009
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
Failed to install in my 2013 trek mtb bike. what tools needed for us be able to install or need washer. Also need to know the comlete package and parts included when you buy it
First, you're going to need to know what type of bottom bracket is on the frame of said bike. Hopefully it will be a standard threaded BB. It could be a BB90 or PF90. If there are no threads in the BB where your BB cups then your working with a press fit system. Let's start with what should come with your Truvativ Noir Crankset. You'll have the drive side arm & spindle, non-drive arm. 3x2.5mm spacers,1x wave washer. The Noir crank uses a 24mm diameter spindle, same as Shimano. SO, if your replacing a hollow tech II crank it should be a pretty standard affair. You'll need to know how wide your BB is on the bike frame to know how many 2.5mm spacers to use. The wave washer goes on the non-drive side against the bearing. Make sure to grease the BB before installation. If there are threads in the frame you'll be using outboard bearings. If it's a press fit system you'll be using cartridge bearings that press directly into the frame. Good Luck!
Sep 09, 2013 | Sram TruVativ 2010 Noir XC 3.3 Team...
Hi I'd to change the original crankset and rear derailleur of my Merida AM400D (Shimano Deore) with the Shimano SLX. Any difficulties in doing so???? Thanks
The deralleur is cake but the crank may present problems not so much mechanically as in the 'q' factor or distance from the frame center to where the chainrings and pedals will rest. Sometimes when you change cranks you get a different effective depth of penetration by the bottom bracket so your chain lne may be difficult to adjust for good shifting.
I don't know an easy way to deteremine the end result prior to just trying it. A Bike Shop migh thave some data and recommendations for BB length.
This site gives a lot of good advice plus they sell the special tools you WILL require to remove the old cranks.
http://www.parktool.com/blog/repair-help
http://www.parktool.com/blog/repair-help/chain-line
Mar 14, 2011 | Merida AM 400-D
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
Clicking crank when pedalling - new bearings or crankset?
More diagnosis on your part required. Unless the crank is hitting something in its rotation (like the errant end of the front derailleur cable in the path of the right crank), clicking will be a bearing and not the crankset itself. Now, is it the bottom bracket or maybe just a pedal?
You could remove or drop the chain onto the frame (shift to the smallest chaninring first, then cover it with a cloth to protect the frame) and manualy rotate the crank without touching the pedals, feeling for the click, maybe even place your ear against the seat tube to hear it better.
If you have toe clips or clipless pedals try to generate the click by pedaling with only one leg at a time. That might reveal a pedal issue or which side of the BB is dying.
Mar 22, 2010 | Cycling
New kmc 10speed chain skipping over a newer durace cassette
If you replaced the chain yourself , you may have left it too long. With the chain on the biggest cog on the rear and the biggest cog on the front , pull the two ends of the chain together and see where they will link up. Leave another two links in the chain and it should be the correct length. You may also have the wrong chain for the bike. Also carefully check each tooth on each cog front and back for wear. Also check the idler wheels in your rear derailleur.
Mar 29, 2009 | Cycling
Chain rubs inner front derailleur while in lowest gear.
on front derailleurs there should be two small cross head screws one has L(lower) next to it the other has H(higher), you will need a cross head srewdriver, you simply losten or tighten the 2 screws and it will adjust the position of the derailleur to your crankset and it that completely fails then you might need to try a different crankset
Feb 26, 2009 | Sram Cycling
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
