Question about Brother LS 2160 Sewing Machine
How to fix the bulb for LS 2160
The bulb came out & I need to re fix the bulb
My brother ls2160 is new. nothing is moving.
Brand new? Take it back to the vendor where you purchased it. No use fussing with a unit that is defective out of the box.
Jan 07, 2017 | Brother LS 2160 Sewing Machine
Why is my brother ls2160 is sewing fine on cotton but not on the material I am using. Its a stretchy silky kind of material. What am i doing wrong?
You may need to use a walking foot with your machine as stretchy fabrics are hard for the feed dogs to 'grip' and pull the material through under the needle.... you will probably need to change needle as well... there should be a helpful video on YouTube that will tell u all about sewing with stretchy fabrics and how a 'walking foot' works... hope that helps.
Jul 20, 2014 | Brother LS 2160 Sewing Machine
My Brother LS 2160 is threaded but not stitching
Hi there Kathryn... when you load/thread the top cotton through the machine.... and then through the eye of the needle.... do you also load the bobbin case... or is it already in there and loaded as per instructions... ? What I normally do... is load up the bottom and top threads first.. making sure to put the top thread through the needle and make the thread end go through and behind the 'foot'... when placing on fabric to try... I make sure to load the fabric... with the top thread's tail going out through the presser foot and behind your foot.. sometimes.. if its the thread (some machines don't like certain threads)... I will manually (wind the right hand wheel) so that the machine does a few stitches.. before I use my foot pedal!.. I have both a serger/overlocker... and a Brother 8500 (sewing/embroidery machine).. I have been sewing for over years now...
You will need to change your needle... when you've used it for more than 6-7 hours continuously.. OR you notice that the stitches are not as they should be... in your fabric...
Mar 22, 2014 | Brother LS 2160 Sewing Machine
I am having issues with threading my machine. I have followed the instructions but every time I sew on the machine the thread on the top sews correctly but underneath the cotton gathers up. What am I doing...
If the thread is bunching under the material it is the top tension. While threading the machine be sure the foot is in the up position until you are done threading it. If you have tried that and it still bunches you need to tighten the tension a bit at a time until it starts sewing correctly. Be sure you are starting with a clean machine and that the thread is not too large for the needle ....
hope this helps.
Nov 25, 2013 | Brother LS 2160 Sewing Machine
Reverse switch not working anymore?
the reverse gear could be damaged or come loose,, it would be a good idea to have the machine checked
Oct 15, 2013 | Brother LS 2160 Sewing Machine
How do I open the case to fix the belt on my Brother LS 2160 Sewing Machine?
Open screws that attached to casing then open front cover of the casing.
Aug 29, 2013 | Brother LS 2160 Sewing Machine
The correct way to fix the needle
With the foot in the up position, loosen the screw that holds the used needle and take it out (throw it away, a bent needle is useless)
Insert the new needle from below, making sure that the flat side is towards the back, and the needle is inserted all the way up. Then carefully tighten the screw as tight as possible. Check that the needle doesn't "wiggle".
Jan 29, 2013 | Brother LS 2160 Sewing Machine
Machine stopped working after bulb fried
it sounds like it's an electrical problem or fuse. you can check with
brother customer service to see if the sewing machine has a hidden
fuse.
Nov 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
Bulb is fused
There is no problem if the bulb was busted,just dismatle it replace a new one.Open face cover plate where the bulb was socket.turn bulb in left drection from the socket to pull out.Be sure the power was off no power supply). replaced a new one.
Feb 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS 2160 Sewing Machine Logo
67 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
