Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I'm having the same problem. tried replacing the bulb,....same problem. so i decided to replace the capacitors on the power board that someone mentioned on a different site...nothing changes. same blinking timer light.
  • pete_nccvt Jun 24, 2009
    sorry...it was the dm caps i replaced......still having the same problem.
  • Mitsubishi Master
  • 8,617 Answers
The blinling timer light is caused by the DM capacitors not the power board caps.
Posted on Jun 22, 2009
Samsung 56" DLP
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Televison & Video
I have a 50" Akai TV - that will not turn on
Good day!!!!
Jun 18, 2012 | Akai Televison & Video
When you turn tv on the power light blinks green picture comes on for a second then goes off then the power light blinks 4 times, also replaced bulb & one of the fans but cannot reset bulb setting...
In that case the power supply of your television have problem.Maybe there's a loose connection in the power supply board or maybe there's a leak capacitor.If you have no knowledge in repairing television and you want to do at your self, first things to do is to remove the back cover of your television.Look the power supply.Remove the screw and the cover of the power supply and try to resolding the board.Check if there's aleak capacitor.The leak capacitor have rounded shape at the top while the good is flated shape.Replace the capacitor with the same value.
Aug 20, 2011 | Televison & Video
Hi, I have a KDS R50XBR1. The problem is, few times the comes on, most times, it does not. The POWER/STANBY LED flashes four times. I have opened the back panel and used dust remover to cleaned all the...
Bulb 1 1/2 or 2 years already?Tv used daily like 4 or 5 hours?Could be the bulb,might not.Check the tv power supply board,that the board,where the power a/c cord plug into it.Look all around the power supply board for dying capacitors parts components.Dying capacitors components are alway bulging up or puffing up on it tops.If is does have it.Than ur tv have power supply board problem.U have all the tools like a soldering iron,desoldering pump or a roll of desoldering braid?Can u do basic soldering and understanding basic electronic?Yes,replace all those dying capacitors,will solved this problems or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 03, 2011 | Sony KDS-R50XBR1 50" HDTV
Did you get yours fixed? mine shows a blinking red light for the same model when plugged in but will not turn on. trying to decide if i should try to get in there or not to fix it...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem....
Dec 26, 2010 | Akai LCT3285TA 32 in. LCD Television
Magnavox 50ML8105D/17. We moved and the tv worked fine and now nothing. Just 2 red lights. Temp and Bulb. I replaced the bulb about 6 months ago. all I did was move.I carried it myself. I have checked and...
My magnavox died due to cheap capacitors on power supply board, a common problem for magnavox tv's from wot i found on net!
I replaced a 2200uf 10v electrolytic capacitor and it works now:)
My tv would take a few atempts to turn on and finally would not turn on,light stayed red!
i recommend visually checking for bulging or blown capacitors on power board, if it all looks good, try warming the board with a hair dryer, this might be just enough to get it to fire up, so at least u know the prob is in that area.
I looked for a 2200uf capacitor near the low voltage output from board n replaced it, got lucky first one, I was expecting to replace all the low voltage electrolytic capacitors.
Justin
Feb 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Same problem
The fateful Green LED Blinking problem can be fixed only in my opinion by sending the Chassi Assay. out to Mitsubishi for Refurbishing. It is a costly endeavor but it will fix it. You can contact Mitsubishi at 800-332-2119. They will need to refer you to a Auth. Mitsubishi Service Facility to come out, remove, and reinstall chassi. Refurbishing of the Chassi would cost aprox. 700.00 to 800.00 plus Labor and Service Call Fee if any.
I hope this helps,
Skyassoc
Jun 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Bulb firing, won't stay on
Try to clean the air filter it soubds as if that is the problem. Then try it aain. If you need further assistance let me know.
Jan 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
