Question about Dymo Organizer Xpress Pro Embossing Label Maker
How to cut finished labels - Dymo Organizer Xpress Pro Embossing Label Maker
    Habit-Forming:
    New Friend:
  • 177 Answers
The printer has a cutter beneath the label. Slide it to one side.
Posted on Oct 06, 2017
Roland PC60 - flashing lights - why?
This happens occasionally with myself if I am printing a large number of labels which is taking a while and decide to cut off some already printed labels from a previous job off from the roll before the current label job has finished. It then feeds the roll back past the edge sensor on the front, gets confused and flashes the lights. I don't unfortunately know how or if the printer can be restarted from this point. If I do i'll post here or if you manage to fix it please let me know. It has something to do with me cutting the roll and the roll passing the front edge sensor.
Jan 26, 2010 | Office Equipment & Supplies
Ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Apr 18, 2009 | Brother P-Touch 1180 Label Printer
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
Lightscribe problem.
Dear JustinMule,
If your lightscribe won't finish making the label, check the label quality and make sure it's on the basic setup (there is a high density option). See if that helps, if not you may have a buffering problem with the burner.
Jul 29, 2008 | HP Pavilion dv6000z Notebook
Samsung CPL-300 Color Laser Printer Problem W/ Labels
I work in the comercial printing game, what your describing sounds like the surface finish used on these labels is only suited to black toner. Black requires the least amount of heat to set, where as colours require more radient heat the lighter the colour gets from black. Try printing a black/monotone lable and see if you still get this blistering problem.
May 07, 2008 | Samsung CLP 300 Laser Printer
Printing die cut labels on Zebra Z4Mplus?
Set the printer to transmissivefrom reflective gap sensing.
This will cause the printer to loog for the inter-label gap to tell it where the top of the label is at.
Steve Weinrich
LazerTek, LLC
Dec 15, 2007 | Zebra Z4Mplus Label Printer
Spits out label but cuts words off
Problem is solved by pressing the function key until "margin" comes up. Then press function key again while "margin" is selected. Use the arrow key to select the "###". Then once that is selected press the function key again. That solved the same problem I had. Good Luck :)
Apr 15, 2007 | Brother P-Touch 1180 Label Printer
Dymo Organizer Xpress Pro Embossing Label Maker Logo
83 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
GuruGrundy
GuruGrundy
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
