Question about Minolta CF2001 Copier
Copier will not operate
Copier will not allow changes in number of copies or change from color to b&w copies
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
Check that none of the buttons are stuck down.This in many cases will lock out the keypad.
Posted on Oct 05, 2009
  • Minolta Master
  • 6,696 Answers
May want to check that default setting have been set for number and black and white, utilty then default settings reset to factory
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Aug 09, 2009
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
Copy is very light. Cannot open the MENU & hence cannot adjust the darkness of the Copy.
First off all to go to menu Press star (Additional function) - 28 together and again star Go to Function - Density and increase/ decrease the number. DE - DC- 24 Dev - 15 Off - 128 Den - 7-9 And again There may be a number of reasons for a light copy 1. Drum - change the drum if it is run above 10 - 20000 copies 2. Blade - changing the blade simultaneously to improve the copy quality
Thanking you.
Jul 02, 2011 | Canon imageRUNNER 400S Copier
How do you change the default power up mode from color copy to black & white?
You will ahve to set up exactly the conditions you want for the default reset. Color option, quantity, manual or Auto exposure, etc. Then press the additional Functions key, then copy settings, press the down arrow key until Standard Settings is displayed, then depress it and then store key not initilize then OK ( YES ). This should get you in the general area of storing the settings you want.
Jun 17, 2011 | Canon imageRUNNER iR C2880 Color Copier
How to change the power on default copy mode form color to black & white.
Hello Gary
On the main copy display your device is probably set to the factory defaults which means that when you press reset the device is in "AUTO COLOR". Touch the "AUTO COLOR" tab on the screen and a drop down menu will show. Select "BLACK AND WHITE". Now press the "ADDITIONAL FUNCTIONS"key. Select COPY SETTINGS located at the top right. Scroll down till you see STANDARD SETTINGS and select it. Press STORE. You are fixed!!! Please let FIXYA know I helped. :-) SPINAL
Jun 17, 2011 | Canon imageRUNNER C3380i Color Copier
How to change the default power on copy mode from color to black & white.
I'm not familiar with this particular model but if it's like the IR color copiers this should help you. First select the black mode for the copier, Then press the additioanl function key, then copy settings, then look for standard settings. I can't remember if you have to use the arrow keys at the bottom to see this. Anyway select standard settings, then STORE, then then confirm these are the settings you want then YES. Press reset and see if the settings are what you wish.
Change my aficioDSM635 language
A. Press the {User Tools/Counter} key.
The User Tools main menu appears.
Note
? When the key operator code is set, the key operator code input
display appears when changing the default settings. Enter the
registered key operator code beforehand.
For key operator codes , see "Key Operator Tools", General Settings Guide.
B. Press [Copier/Document Server Features].
The Copier/Document Server Features menu appears.
C. Select the menu you want to set.
The setting display for each menu appears.
Reference p.83 "User Tools Menu (Copier/Document Server Features)"
D. Change settings by following the instructions on the display panel,
and then press [OK].
Exiting User Tools
A. After changing default settings, press [Exit] on the User Tools main menu.
Changes to User Tools are complete, and the machine is ready to copy.
Note
? You can also exit User Tools by
pressing the {User Tools/Counter}
key
Dec 17, 2010 | Office Equipment & Supplies
Cf2001 will not allow use of copier
I assume you unplug the machine, does it have a internal fiery? have you open and close the front door, Also check user settings.
Jun 22, 2009 | Minolta CF2001 Copier
Sharp ARC270, washed out color
I would have to say that they did it wrong or that you have a transfer or drum charge problem
Jul 08, 2008 | Sharp AR-C270 Color Copier
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
71 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
