Open vertical size - Televison & Video
  • 69 Answers
Over expanded screen vertical limter cap on the neck board typ .001 1000v
Posted on Jun 24, 2009
Vertical size of screen is bad. very big. please solve this problem.
You have too much vertical scan amplitude this could be due to higher voltage on dc line to vertical amp or broken amplitude control , maybe short circuit capacitor on feed to scan coils, or transductor open circuit windings , could also be open cct in negative feedback loop.
May 19, 2014 | Toshiba Televison & Video
H size problem h size is too high
if its top and bottom it is vertical issue and not horizontal, some sets have adjustments for this and others do not. Model?
Nov 28, 2012 | Televison & Video
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
How to adjust vertical size my hitachi c29-r30sp
You could go into the user menu and look around to see if it has an adjustment. If not you will have to access the service menu for your tv. There may be a setting to adjust vertical size there. If that still isn't possible you may have to open the tv and look for a pot or a switch that can control the vertical adjustment. It may be by the vertical output circuitry. This could also mean that you have a defective component in the vertical circuit or inadequate voltage to that circuit.
Mar 11, 2010 | RCA F27440 27" TV
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
Monitor Curcuit Problem
re-adjust the vertical and horizontal size then exit the menu
Oct 22, 2008 | AOC LM729 17" LCD Monitor
Loss of proper vertical deflection
Check the info here: //http://wa6ati.com/Mga-tip.html
Jan 22, 2008 | Televison & Video
Full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Oct 18, 2007 | HP Compaq FS7600 17" CRT Monitor
Vertical size
make checks on your vertical it could be getting too much voltage replace it along with some cap around that are not filtering the voltage to the ic.because it have cause damage to your vertical change all related components in that circuit also check the related circuits.you can get a schematic for your set at www.samsphotofact.com good luck
Mar 29, 2007 | Panasonic PT-51G44 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
