Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Where is the reset button on a TI 84 Plus Silver Edition
  • Texas Instru... Master
  • 8,016 Answers
There is no button. You use the key sequence [2nd][+] (Mem) 7:Reset.
See the screen captures below.
where is the reset button on a TI 84 Plus Silver E - 921d210a-6691-4c13-b810-82e85ff8de95.png
Be careful what you do with the Archive and All selections. You can explore them but do not confirm any resetting unless you understand all that it will do.
Posted on Aug 28, 2014
  • 56 Answers
SOURCE: Garbage Collecting
graphing calulators work much like computers. The have RAM space so they can remember what you have done recently and stuff like that. So when it's garbage collecting it means it's trying to find more space. This generally means that you don't have much much ARC or RAM space left. You can see this under your memerory manager. (2nd + enter) then you can reset your calculaor(2nd plus 7 1 2) or you can go to memory manager and unarchive your programs. Fur an example you have TI 84. Most new TI 84 have sientific tools. so if you don't you it take away the archive (*) by pressing enter and then hit DEL. the more RAM space and ARC space should make it so it doens't garababe collect. Hope this works. i can help you more if this doesn't work. GOOD LUCK
Posted on Jan 25, 2008
SOURCE: ti 84 plus silver edition language change
The easiest way to fix this is through the Apps menu. Hit the apps key, then scroll down until you see any language(espanol, Deutsch, etc.). It should give you the option of switching to either that language or restoring to English. I just tried this on a calculator that was set to German. I hit Apps and scrolled down until I recognized the option for Spanish, and it still worked. It let me switch back to English.
Hope this works for you.
Posted on Dec 09, 2008
  • 192 Answers
SOURCE: Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
Posted on May 29, 2009
  • 88 Answers
SOURCE: frozen ti 84 plus silver edition
Ther is no reset button. You have to take the batteries out.
Take the AAA batteries out and take the back up battery out...located in a little door with a screw just above the AAA batteries. Leave the batteries out for about 8 hours. This is how you reset a TI graphing calculator.
Posted on Aug 29, 2009
  • 8016 Answers
SOURCE: TI-84 Plus Silver Edition FROZEN
The first part of the post is inserted for completeness (and in case you need to readjust the scree. You can just skim through it.
Part A or B will reset the memory. Please read the whole post before attempting the procedures described here.
The first diagnostics you should perform are:
  1. Make sure batteries are good and inserted correctly, respecting the polarity diagram: Yes, I myself made this mistake and it must be ruled out before doing anything else.
  2. After a change of batteries, the screen contrast can change: It may become too dark or too light. If it is too dark, you would not think about a malfunction because you see something on the scree. BUT it the screen is too light, it is easy to conclude that there is a malfunction because you do not see what the calculator is doing after you press a key.
  3. So, the second measure is to adjust the contrast. Press [2nd] key and Release it. Then Press and HOLD the UpArrow until screen is dark enough.
  4. A third easy measure is to use the TIConnect software (available on education.ti.com) to retrieve the device Info, and if calculator is recognized to reinstall or update the OS. You need a TI USB SilverLink cable.
Here are some more procedures to perform in the order they are presented. Please read the post till the end.
A
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. While holding [CLEAR], reinsert the AAA battery and then
  4. turn the calculator on.
  5. the calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
B.
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary. (see above)
C.
This step requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. While holding [DEL], reinsert the AAA battery and then
  5. the calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculator
  • Serial Black cable that used to ship with the TI 83 Plus. It connects to a serial port on a computer and to the I/O port on the calculator. It requires the Graph Link software available on the TI web site (Downloads, Software and Apps, Connectivity)
  • USB Silver Link cable. It connects a USB port on the computer to the the I/O port on the calculator. It requires the TI connectivity software, also available on the TI web site.
  • An I/O cable to connect two calculators through their I/O ports.
Posted on Jul 31, 2010
None of the buttons on my TI-84 Plus Silver Edition will work
Does it turn on with a cursor, Have you tried a fresh set (all four) of batteries, Is there any corrosion/dirt on the battery contacts and the I/O port that you can see, Have you tried any resets?
Jun 09, 2014 | Texas Instruments TI-84 Plus Silver...
Ti-84 plus c silver edition will not turn on
Try reinstalling the OS, that might resolve the problem.
Jan 23, 2014 | Texas Instruments TI-84 Plus Silver...
Cant find ! button
There is no such thing as a TI89 Plus Silver Edition.
If you mean the TI-89 or TI-89 Titanium, press diamond / (the diamond key below the 2ND key, then the divide key).
If you mean the TI-83 Plus Silver Edition or the TI-84 Plus Silver Edition, press MATH left-arrow 4 .
Dec 15, 2013 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus Silver Edition not responding!
what helped for me is leaving it w/h any battery's (no backup battery either) for a few days. Now miraculously it works!
May 06, 2010 | Texas Instruments TI-84 Plus Silver...
Frozen ti 84 plus silver edition
Aug 18, 2009 | Texas Instruments TI-84 Plus Silver...
Where do I find the comma button on the TI-84 siver edition?
The comma is located on top of number 7 key.
See page 5 on teh user manual to learn how to operate the keyboard on a TI 84 Plus:
TI-84 Plus TI-84 Plus Silver Edition Guidebook
Mar 16, 2009 | Texas Instruments TI-84 Plus Silver...
Waiting Please Install Operating System Now.
i finally fixed my calculator~
1. if you have a ti 84 plus silver, plus, or just ti 84, find a friend who has either a ti 84 plus silver, plus, or just ti 84. (as long as the number is the same)
2. link the two calculators together
3. using your friends calculator, press the [2nd] and the one next to alpha [x,t,o,n]
4. go all the way down to [send os]
5. send it to the other calculator and your problem should be fixed
Aug 27, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
147 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
