Question about Sony Video Cameras
I have a sony handycam. problem is C:13:02 error. how to solve the problem?
Handycam dcr dvd 403e
SOURCE: Sony DCR TRV33 Handycam Driver
i have lost my driver for my Sony DCR TRV33 Handycam Driver. Can you help?
Thanks
Posted on Jan 17, 2009
Fixe_You
  • 1800 Answers
SOURCE: SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Posted on Jun 28, 2009
megarza
  • 88 Answers
SOURCE: Driver of Sony Handycam DCR-TRV285e
you can download the drivers here http://support.sony-europe.com/dime/camcorders/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV285E
Posted on Aug 20, 2009
  • 497 Answers
SOURCE: Installing software for my Sony Handycam DCR-HC96
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Or you can purchase the software disk from this link:
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=partSearch&searchText=266675501
NOTE: Since the original supplied software is not available for free download now.
Good Luck!!!!!!!!!!!!
Posted on Oct 01, 2009
SOURCE: SONY HANDYCAM DCR-35E
I had the same problem. When I purchased my HDR-SR11 camera some four years ago, I was running XP and the PMB Disc Burning worked well. When I changed over to Windows 7 I kept bombing out like a lot of other users. The problem was that I was using an old version of PMB (3.0.00). I went to the Sony web site and downloaded the latest version of PMB with an upgrade (0810a.exe) This fixed my problem and the Disc Burn function workes perfectly now.
Posted on Nov 04, 2010
I have a Handycam sony camcorder (DCR-DVD403E PAL and i can't see the photos because it appears the error C.13:02. How can i can repair this error? tHANKS FOR YOUR HELP.
I have a Handycam sony camcorder (DCR-DVD755E PAL and i can't see the photos because it appears the error C.13:02. How can i can repair this error? Pl. help me to solve the problem.
Sep 25, 2011 | Sony Handycam DCR-DVD305 DVD Camcorder
Sony handycam dcr-dvd201e disc error c:13:00
You are using DVD+RW instead of DVD-RW. This camera does not support DVD+RW.
May 24, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony DVD Handycome does not work with Vista OS via USB connection
this is what I found online. good luck
http://www.camerahacker.com/myink/ViewPage.php?file=docs/Connecting%20Sony%20Handycam%20to%20Windows%20Vista%20Via%20USB
Mar 09, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
I have a sony handycam dcr-dvd 340 which is displaying recording
Format mini DVD disk with camera Menu format option.
This will solve your problem.
Jul 03, 2009 | Sony Video Cameras
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
I have a HANDYCAM SONY DCR-DVD 106, and I keep getting the following message error - "Disc error. Unsupported format - 13:023, with regard to a mini MEMOREX DVD-R.
Disc error. Unsupported format means that ur camera does not support the format of this disc it might not support DVD-R or DVD-RW and supports the DVD+R and +RW try the other format disc and let me know if it resolved , check the manual it is stated on the box or manual which format it supports, if it does not solve ur problem try some other brand instead of MEMOREX try sony,hp,fuji,philips and see actually these sony cameras they are sometimes locked by the manufacturer to only use the original discs for monopoly sony acts like that in every product
pls do rate me if i fixya problem
regards
Zohail
Feb 23, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
DVD Error sony handycam DCR-DVD108
Reformat DVD and clean Lens with soft n nice quality cotton swab.
Jul 22, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam disc error when i try and finalize it
what type of disc--r -rw +rw? try to finilize in someone elses camcorder if possible and see if it reads it-does it play in camcorder still?
May 06, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Video Cameras Logo
18 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
