Question about Kicker ZX450.2 ZX Series 2 Channel 225 Watts Per Channel Amplifier
What color light should be on when a kicker zx450.2 turns on
When i turn on a kicker zx450.2 a red light lights up around th zx logo is this ok
zzedly
  • 300 Answers
SOURCE: green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Posted on Mar 16, 2009
  • 5 Answers
SOURCE: kicker zx1000.1 the green led turns off and the red is lit
check your wiring make sure it is not grounding out check you sreaker wiring make sure they are not reversed +to- make sure it has plenty of air ti breath make sure your speakers are wired for two ohms or four it is not stable for one ohm it has a circuit protection if any one of these thins are happening it will kick the red light on and shut down.
Posted on Mar 22, 2009
yungdub
  • 93 Answers
SOURCE: kicker zx1000.1 green light flckers and the turns red and then does the same thing over and over
seems like a protection feature kicks in and out
check your fuses and possible but a bigger size in and also check your wires make sure your ground is tight
Posted on Jun 14, 2009
fixerdlt1
  • 18 Answers
SOURCE: kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Posted on Jul 22, 2009
Bennytechkid
  • 99 Answers
SOURCE: MY KICKER ZX 750.1channel amp "FLIP FLOPS" from
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Posted on Jan 04, 2011
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but...
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but still th problem is same. please help me
Oct 03, 2010 | Sony Ericsson XPERIA X10 Cell Phone
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
please advise
thanks,ben
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
Kicker zx 1000.1 green light flickers and no sound
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
Kicker zx1000.1 the green led turns off and the red is lit
Mar 22, 2009 | Kicker ZX10001 Car Audio Amplifier
My kicker zx 750.1 amp is not working.
that is protection built into the amp. try turning down the gain levels on the amp
Apr 20, 2008 | Car Audio & Video
Kicker ZX 750.1
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Apr 12, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Kicker ZX450.2 ZX Series 2 Channel 225 Watts Per Channel Amplifier Logo
54 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
