Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Change screen size without remote - Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do i adjust screen size on a jvc 48 inch tv without remote?
go through menu untill you find screen page and change aspect ratio setting use up and down volume to change it
May 18, 2014 | JVC AV-48WP30 48" Rear Projection...
How to change the screen size on a Westington TV
Hey,
In order for you to change the screen size on your Westington TV you have to press on Format on your remote (it is the button between the volume and the channel, right under the input button). As you press on it, it will change the display. From
  • Standard: Picture is displayed in its original size.
  • Fill: Picture is displayed to cover the entire screen.
  • Overscan: Picture is scaled down to fit the display area.
  • 1:1 Mode: Matches the incoming resolution exactly to the pixels without any scaling.
And now everything should be good!
Enjoy!
May 13, 2014 | Westinghouse 55" Class 54-5/8" Diag. - LCD...
Change the picture size without the original remote
To select the aspect ratio of picture, you should have its remote cotrol.
Dec 22, 2013 | Sharp 32L-S400 32" TV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
Feb 28, 2010 | Toshiba 37WLT58 37 in. LCD TV
Element LCD 32" TV- expand the screen
You will need the original remote to operate the different screen modes.
My TV has the same problem, without that silly special button on the remote, I'm not able to change the screen size without it.
I google "FLX3210 remote", 3 web sites are selling it for less than $45.
I hope I answered your question correctly. Please rate me
Feb 25, 2009 | Element Electronics FLX3210 32 in. LCD TV
Wide screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
The name of the button on the remote is called format.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 18, 2008 | RCA F27650 27" TV
The picture is too big for my screen
press zoom on the remote control to get the normal size
Dec 24, 2007 | Toshiba 35A44 35" TV
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
16 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
