Question about Marantz SR6001
Marantz av surround receiver sr6001
The standby light is flashing rapidly and the display wont turn on, help?
3 Suggested Answers
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Posted on Jun 13, 2011
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Posted on Apr 06, 2012
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
Tv does not come up standby light keeps blinking
It seems there is no information in the manual here http://www.finluxdirect.com/content/ebiz/shop/resources/pdf/46S8030-T.pdf
So you may want to attempt to talk to their support. They have free on line chat here Finlux Direct Help Centre
Good Luck
Apr 10, 2014 | Finlux 46S8070-T 46" LED TV 1920x1080, 100...
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
I have a Sharp LC-22L 10M TV, it has gone off with the standby light flashing red and wont respond to any controls. If I power off at the mains supply and back on again it comes on for a second and then...
Flashing standby light indicates internal circuit problems. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there
Nov 26, 2012 | Televison & Video
What is the setting for the Marantz SR6001 channel 2
It's not clear what you're requesting but I'm sure it's in the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR6001-Receivers-manual/id/2536ag202/t/2/
Apr 09, 2011 | Marantz SR6001
Standby light is flashing rapidly and I cannot turn on
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
Feb 27, 2011 | Marantz SR7002 6.1 Channels Receiver
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Marantz SR6001 Logo
51 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
