Question about Refrigerators
Refrigerator door does not seal
Fresh Food door does not seal on bottom handle side. Gap between closed door and refrig is 5/16 inch greater at bottom than at top on handle side (1+5/16 on bottom vs 1 on top). On hinge side gap is 1/4 inch greater at bottom than at top (1 on bottom vs 3/4 on top). I have leveled refrig side to side and front is 1/2 inch higher than back. Refrig is just a couple years old and gasket appears to be in good shape.
  • 56 Answers
SOURCE: Refrig door gasket does not prevent gap when door is closed
Lift up the gasket and look for screws securing the gasket to the door.
Loosen all of these screws a few turns and twist the door in the direction needed to seal.
Hold the door in this position as you tighten the screws.
This can be tricky and sometimes requires multiple efforts.
Posted on Apr 03, 2009
  • 864 Answers
SOURCE: door gasket gap
Apply a small strip of soft foam weatherstripping tape to the frame in the area of the gap.  You may have to taper the ends slightly to match the gasket profile or the foam tape will force the gasket open for a greater length.
Posted on May 30, 2009
  • 212 Answers
SOURCE: Refrigerator door not closing
look at bottom of door. there is a metal bracket called your door stopper. this only allows door to open so far. if pushed open to far then you bent this bracket. bent back to normal position. your door will close
Posted on Jun 21, 2009
  • 113 Answers
SOURCE: Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Posted on Sep 15, 2009
  • 41 Answers
SOURCE: i think the hinge has sprung on the frig door. it
check the door hinge brackets there are plastic bushing they may be damaged causing the door to have slack in it open the door and take the handle and pull it towards you there should be no slack if there is it could be a bushing or just a loose hinge
Posted on Nov 20, 2009
Testimonial: "no slack. thanks for that feedback. i'll proceed with the gasket seal. was this in response to magic chef model? i mistakenly put whirlpool to start."
Refrig door does not seal
First off, make sure nothing is stopping the door from closing completely. If the door is closing properly, then using a hair dryer, heat the gasket until soft and pliable. You can carefully stretch it towards the cabinet. There is a magnet in the gasket all the way around on the mating portion. While the gasket is soft, the magnet will pull the gasket until contact is made with the cabinet. Once a good seal has been accomplished, allow to door to remain closed for 30 minutes. The seal will cool down, and the new shape will be maintained. After that, close the door on a dollar bill. Gently tug the portion of the bill on the outside of the door from one corner to the other. There should be some resistance to your pulling. If the bill feels loose, apply more heat to the gasket in that area to improve the seal. DO NOT HOLD THE HAIR DRYER IN ONE PLACE TOO LONG AS IT WILL DAMAGE THE GASKET, AS WELL AS THE PLASTIC LINER.
May 08, 2014 | Refrigerators
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
I think the hinge has sprung on the frig door. it
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer drawer jars open at upper right corner when refrig door is closed. Air leaks in and is forming frost on frozen food.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Nov 05, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Jun 21, 2009 | Whirlpool Refrigerators
Changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Phil
Jun 10, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
Apr 03, 2009 | Haier HSL06WNAWW Compact Refrigerator
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
