Sony kdl-32l5000 clicks but no power or standby led
Power supply is good
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40V300 won't turn on.
Unfortunately 5 blinks is a LCD panel error. The only way to fix it is to replace the whole LCD panel. This is the most expensive part in the TV.
part number: 1-802-488-12
List price: $1336.32
Core charge: 1790.00
You could try to replace it yourself but would need to take the whole TV apart by first taking off the back cover, then removing all the boards in order to get to the panel before putting it back together but I would just recommend buying a new TV as the price of the repair exceeds the price of a new TV of the same size.
Posted on Oct 13, 2009
pappapumpdaf
  • 635 Answers
SOURCE: Sony KDL-52XBR9 power/standby LED blinking. TV
This is either your LCD backlight, inverter/power board or both. Neither of which are serviceable by the consumer, unless a visual inspection of the power board shows swollen or ruptured capacitors. This you can do yourself and is the most likely problem. Just read the side of the capacitor and go to radio shack, or online to find the right replacement capacitor. When re soldering be sure your negative and positive leads are in the correct holes.
Posted on Mar 12, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: My Sony KDL-26S3000 won't turn on it well get stuck in standby
Please see the troubleshooting chart, BU1 board part # A-1268-869-A, cost approx $230.7685cfa.jpg
Posted on May 23, 2010
frankgilbert
  • 613 Answers
SOURCE: Sony,KDL-32L5000,LCD TV,REMOTE WON'T TURN IT
Sometimes one button on your pad gets stuck. Sometimes we get liquids on the pad. I suggest taking out the battery(s) and using high grade alcohol (90%) and swabbing the pad real good and let dry or use hair dryer. Is this a factory remote?
Posted on Jan 02, 2011
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony model kdl-32l5000 only works by unplugging and plugging back after about 5 minutes
power supply may need recap try with a hair dryer when tv in stanby to heat a bit without unplug it if after heat it will start?
Sep 14, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
The standby mode is not working tv will not go on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 08, 2014 | Sony Bravia L-Series KDL-32L5000 32-Inch...
Sony Bravia KDL-55nx720 My tv is stuck in standby mode. Blinking twice.. Would replacing the power supply possibly fix this problem? Please help.
Normally yes. Blinking twice is power protection trip. Look first for open resistor, broken fuses (and short circuits or broken transistors / ICS if thats the case).
Oct 05, 2013 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Bad power supply?
First of all, please ensure that the power outlet is ok. During such power surges, normally the power outlet gets affected. Try the TV on a different power outlet. The relay clicking on/off could be due to some components short in the primary supply.
Aug 26, 2012 | Sony Bravia L-Series KDL-32L5000 32-Inch...
Kdl32l5000 no power
Sony 32L5000 Power supply not likely gone bad unless the fuse blow. If there is a click sound and vold meter read 3.3v (standby) on the far top right terminal mean you power supply still good. If no led light on the front that is the bad main board (board with tuner box and RCA, hdmi plug) My replace and work like a charm.
Nov 18, 2011 | Televison & Video
I have a Sony Bravia 32" t.v. model number KDL-32L5000. My t.v. turns it's self off periodically. I have looked at the sleep mode and it shows it is off. Could there be something else that may force...
The same thing happened to me. I went to Menu. Click the bottom item and when it opens, click on ECO. Now turn off both Power Saving and Idle TV Standby. It is mostly caused by the Idle TV Standby, though. Good luck!
I am still working with the loss of the IR capability. I sadly found the Warranty docs when it had ended...
Jan 19, 2011 | Sony KDL32L5000 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
