Question about Conair Weight Scale "Thinner" with Body Fat, Hydration, Bone Mass
How to change the battery in conair th204W? - Conair Weight Scale "Thinner" with Body Fat, Hydration, Bone Mass
How to change battery on TH204W thinner scale
Take it outside & make sure you are in a clear space & have any 1 there besides yourself step back at least a good 5-10ft! Always wear protective eyewear while doing any type of maintenance with your scale or any other products alike! Next u want to find the most durable quality sledgehammer money can buy & use with extreme force rite in middle of scale! I'm sure other tools could be used but this 1 seemed to be most obvious to use! Take a good 3-5 hits unless u have extra stress that needs some relief then continue to take whacks at that thing till feeling of satisfaction has consumed you! Use broom & dustpan to gather all debris to 1 pile! Place in box & mail all debris to any Conair address you can find online or on back of product! Also include note on the instruction manual if you still have it but if not a little note card works as well...On note let them know u hope they choke on the 3 button batteries you bought to replace yours according to their instruction manual! Whoever they paid to create that manual should have their junk & peanuts burned off (no offense but no woman would have came up with that useless ****** manual...It would be better served to wipe my stankyass with it after I ****** in the box I'm sending back to conair with their scale)! If you have any questions feel free to ask!
May 20, 2014 | Conair TH402 Thinner Digital Body Fat &...
Where is battery door for conair model th204w thinner scale?
Model TH204W --Batt is NOT replaceable. There are 2 plastic flanges on each side that hold the base to the top. Ea needs to be pulled back with 1 screwdriver while inserting another next to it to pry open the plate. Remove the soldering tape surrounding the display window. Underneath the window is the Batt that is soldered to the circuit board. Doesn't matter since you can't remove the display to access the Batt anyway. The name of the co. is appropriate -- CON air. I urge all to post to them & WEIGHT WATCHERS since this product is endorsed by them & the 'manual' is merely hype for their program.
Jul 10, 2011 | Conair WW81 Weight Watchers Body...
I have had my Conair GMT 800 for about 8 months. The battery will not hold a charge, I can't believe the battery goes that fast.
The battery is a custom made item and is not sold anywhere. It was made for this specific trimmer for Conair. I have the same problem. Great trimmer when it worked, much better than most. I actually purchased a Wahl (Made in USA) trimmer and am very happy with it, although it does lack some features the Conair has (or had). What can I say? Conair is a good company, but I guess this one did not work out.
Rom
Jan 31, 2010 | Conair GMT 180 NCS Beard Trimmer
Conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Nov 11, 2009 | Conair Deluxe Rechargeable Beard &...
Conair Weight Scale "Thinner" with Body Fat, Hydration, Bone Mass Logo
51 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
