Question about Kitchen Ranges
My lights on my Fabyka range hood stopped working. What do I do to fix them?
2 Suggested Answers
  • 4 Answers
SOURCE: I have a viking Professional range hood. While
FLASH covers a multitude of possibilities. What is the voltage of the blower motor. What you are describing often happens when 220 is wired to a 110 lighting circuit. I would not be running the blower motor although I hope it has inherent built in motor protection. If the voltage is applied higher to light bulbs they become flash bulbs. Florescents can become fire fixtures fast. If you are not an electrician back away from this and disconnect power at your breakers. Do not open up and trouble shoot if you are not qualified so you do not get embarrassed and have a dirt nap. It only takes about 40 vo;ts and a few milliamps cross chess to kill you. Also when ever you turn something on start and keep the habit of using one hand to turn it on and one hand to grab your pants behind you. OK OK or skirt. This prevents a cross chest shock . Old Navy (USN) death defeating rule that sved me many times and still. Remember call a pro when you do not know .
Posted on Dec 04, 2009
Fabyka
www.fabykahood.com/contact.asp
Jul 05, 2014 | Kitchen Ranges
How do i change a bulb on a zephyr verona range hood
I could not turn the bulb, and the rubber glove approach did not work. I unscrewed and removed the middle cover, which meant I could easily reach inside and turn the whole light bulb fixture.
Apr 18, 2014 | Zephyr Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Jul 29, 2013 | Kitchen Ranges
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
Stopped working after power outage
If you cannot fix - too expensive or whatever - consider a replacement with a five year 100% parts and labor warranty and in-home service. Imperial (made in USA) is the only range hood manufacturer that offers this. More information here: www.vent4less.com
Regards,
Donald
Jul 12, 2010 | Frigidaire (PL36WC40EC) Stainless Steel...
My neff cooker hood's fan and light suddenly don't work-worked yesterday! please help
My light and Extractor have stopped working. Some1 advised Transformer may have gone. Is it beside Motor and how is it accessed to fix ? Thanks
Jan 31, 2010 | Kitchen Ranges
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Lights stopped working
Have you opened the hood at all? Service instructions should be on the cover of the controller box. FYI the fuse is on the 12V side of the transformer so it which feeds triac controlling lights and controller board so nothing works when it blows.
Sep 23, 2007 | GE ZV850SBSS Kitchen Hood
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
