Question about Car Audio & Video
Sca568 Car stero is not working but display is dimly visible.
The panel display is very dim and hardly visible. Tried to reset by disconnecting the power.
Panel display on what? TV, computer, tablet, phone? If on your computer, try another monitor. (Borrow one if you don't have a spare just to test.) If this one works, you need a new monitor. If this is a laptop, try plugging in a monitor to the VGA connection. If this works, make sure you don't have the screen dimmed accidentally. If it is the screen, you can get a new screen installed.
Oct 30, 2017 | The Computers & Internet
Whirlpool microwave g2 - Panel lights but no text visible
It is a logic problem or at least electrolytic capacitors that dim the display too far. The display could be repaired if it isn't a ic (logic) problem if it is then you need the whole display replaced
Nov 29, 2013 | Microwave Ovens
System works fine, plays well etc. However, the digital readout is no longer visible. Ideas?
There is typically a dimming feature among these types of systems. There may be a button on your remote/system panel to adjust how dimmed the display through which you can adjust it. If not, then try to enter the system setup mode and adjust the brightness of the display.
OR if the digital readout is not very dim and is in fact blank then your LCD panel has failed. You should replace the panel or get a new receiver. I would start by calling the customer support line as this will surely be under the manufacturer's warranty.
please rate my solution
Jul 31, 2010 | Bose Lifestyle 25 System
Lockd stero
Codes are set by the user, so if you do not have the code then it will not work. I do not beleive there is a way to reset them other than possibly contacting Kenwood directly.
Mar 01, 2009 | Kenwood Car Audio & Video
Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
The light and temperature display are very dim and hard to see.
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 23, 2008 | Jenn-Air JJW8230D Electric Double Oven
KDS Valiant Laptop - Dim display.
Right click on the desktop, select view, then select show desktop icon.
Jun 30, 2008 | KDS Valiant 671DP Notebook
Car stero won't recognise device
Only solution is to switch to a different type of car adapter, like a casette adapter. iRiver is too small for car manufacturers/adapter manufacturers to bother with.
Oct 24, 2007 | iRiver X20 MP3 Player
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
