Question about D-Link NetDefend DFL-700 Firewall
I have an XP pro desktop running a VPN server. I'm connecting to it on my laptop no problem (also running XP Pro.) the problem is that I can't map my NAS (on the same LAN as the VPN server) to a drive letter on my laptop (\192.168etc share).
  • splashscuba Jun 22, 2009
    "the network path \\192.168.1.253\pics could not be found". Yep, used double slash.
  • Troy Anderson May 11, 2010
    What error do you get when trying to map the drive? and you are using \\ right? not just \
  • 135 Answers
What is the error you are getting?
Posted on Jul 22, 2009
Error 720 - the connection attempt failed because your computer and the remote computer could not agree on PPP control protocol. Gateway Desktop
To resolve this behavior, follow these steps:
  1. Find out which protocols the RAS server is running, and make sure that the RAS service is installed and configured properly (or ask the Network Administrator to do this).
  2. After you find out which protocols the RAS server is running, make sure that your Windows XP-based computer is running one of the same protocols that the RAS server is running:
    1. Click Start, click Control Panel, and then double-click Network Connections.
    2. Under Virtual Private Network, right-click the VPN connection, and then click Properties.
    3. In the VPN Connection Properties dialog box, click the Networking tab, and make sure that you have a protocol that the RAS server is running.
  3. If you do not have a protocol that the RAS server is running, add the needed protocol:
    1. Click Install, click Protocol, and then click Add.
    2. Click the protocol that you need to install, and then click OK.
    3. Click Close in the VPN Connection Properties dialog box.
May 30, 2010 | Acer Aspire T650 PC Desktop
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Unable to reach firewall periodically
If you are using the firewall as the DHCP server, you may need to check the DHCP lease period on the firewall & increase it if required.
Mar 24, 2009 | SonicWALL Pro 2040 Firewall
How to connect to my PIX 501 and use Windows Remote Desktop?
Here's a real simple problem to your remote access problems.
Go to: http://www.logmein.com
Sign up for a free acct, download/install their free software on your Server.
Now go over to your laptop, login to your new logmein acct.
In the next page, you'll see your Server listed. Click on it - follow instructions to connect.
This will tunnel through whatever stuff you have on your network!
Trust me - esp. in your scenario, this is *by far* the *simplest remote connect you'll ever perform! And it just .... works! Everytime.
gurutim
Mar 16, 2009 | Cisco PIX 501 Firewall
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Teaming Intel Card
That NIC is end of life ...obsolete
Mar 02, 2017 | Computers & Internet
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
D-Link NetDefend DFL-700 Firewall Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
