Question about Exercise & Fitness
I'm getting an e 1 and an e2 message on the treadmill as soon as I turn on it runs really fast then error displays message . Please help everettetryon@gmail.com
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Where can i download a manual for an image 10.4 treadmill? it displays an E2 or E4 error message. thanks.
Try Retrevo Manuals.com lots of manuals but you really have to search for them. Make sure you gave make, model number etc.
Dec 15, 2013 | Treadmill Doctor Image 10.4 Q Console...
Freespirit treadmill
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
see my personal TIPS for motor help. God bless you 1232c4bc-7349-41aa-9120-7d58645cb442.gifc11b620c-0d7d-410d-9958-64f3636d4ac5.jpg
Jun 05, 2013 | Exercise & Fitness
My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
see this steps and fix it.God bless you
This is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2
Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Oct 01, 2012 | Ironman Exerpeutic TF1000 Walk to Fitness...
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
Exercise & Fitness Logo
20 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
