Question about Panasonic White Kx-t7030 Phone System Telephone Kxt
How do I off the BGM on KX-T7030? - Panasonic White Kx-t7030 Phone System Telephone Kxt
5 Suggested Answers
SOURCE: panasonic kx-t7030
We have misplaced our user manuel for our panasonic KX-T7030. Is there anywhere we can go and download one to print off
Posted on Sep 16, 2009
  • 5 Answers
SOURCE: how do I reset the date/time on panasonic KX-T7030
return it where you purchased it.
Posted on Nov 09, 2010
SOURCE: 4 phones on a boat,model # KX-T7030 No Dial Tone
pdf.textfiles.com/manuals/.../Panasonic%20KX-T7030%20Reference%20Manual.pdf -
Above is a user manual, below is your reference manual.
http://www.scribd.com/mobile/documents/8790207
below is the circuit diagrams.
http://www.eserviceinfo.com/downloadsm/4832/Panasonic_KX-T7030.html
These phones all operate across pairs of wires. Usually the phones plug into a main box called a EMSS, (Electronic Modular Switching System) It has to be set up first, sort of "Programmed" before it will all work together. You need to also obtain the information on the EMSS unit, as this is the "Brains" of it all. The EMSS unit has a power connection, the phones generally do not. There must be wiring from the EMSS module out to each phone.
Once you sort that out, the phones should all simply work, when connected.
Posted on Nov 13, 2010
phil_dedicat
  • 6 Answers
SOURCE: I have KX-T7030, how do i transfer the call to other numbers?
Hi Colleen When you say transfer calls to ther numbers do you mean to transfer one external number to another external number or numbers within the office?
Let me know will explain.
Speak Soon
Phil
Posted on Nov 19, 2012
Panasonic KX-T7030 won't answer. When you lift up the receiver and pick a line the speakerphone button lights up and the phone is inoperable. It's not the phone it's the phone line. Any phone...
Try unplugging the phoen and plug a single line telephone into the port. If it doesn't work, you have your answer. The voice pair, which will use the inner pair of a 4 conductor cable needs to be working before the multi-line set will work. I'm guessing you have the data path but not the voice. The phone looks like it works, but there is no sound.
Carl
Oct 05, 2011 | Panasonic KX-T7030 Corded Phone
I have added a new phone to our Panasonic KX-T7030 system, I can't get it to assign a voice mail box number
Since the mail boxes are assigned in the voice mail system and a 7030 is a phone, I'd start with calling the voice mail system :-)
Mailbox 999 in a TVx system administers the system and allows you to add a mailbox.
Carl
Feb 04, 2011 | Panasonic KX-T7030 Corded Phone
How do i turn bgm on
It depends on what system the phone is connected with. The BGM command is *751 and 1 or 2 for the source dialed on the intercom. It clears with *7510.
Carl
Nov 04, 2010 | Panasonic KX-T7630 Corded Phone
My BGM, back ground music used to work, now it does not. We use it only for music at our work stations. We press BGM for some music then toggle it off if necessary. It automatically shuts off if the...
Since a TD system BGM is just a single press "1" on an idle phone to turn on or off, I'm hard pressed to understand what you mean about BGM being a key. If you press "1" on a display phone and it says BGM On, and it doesn't work, go back to wherever the system cabinet is and look for the BGM port on the side of the phone system. It probably means the source is turned off or disconnected.
Carl
Aug 17, 2010 | Panasonic KX T7436 Corded Phone KX-T7436
Change radio station on Panasonic KX-T7633
Well, it depends. You can have 2 BGM sources on a TDA-100 or higher system. The system in the back room will have 2 MOH jacks and you can select the source from a phone. Since this is also the Music that the callers hear, there may be copywrite issues on playing commercial radio on hold. Most places actually use MOH 1 for a Promotion on hold, and MOH 2 for employee's BGM.
Carl
Apr 28, 2010 | Panasonic KX-T7633 Corded Phone
Kx t7436 Background music
The easy answer is check program 803. It should be set to music1. The harder one is that you need to look at some 990 programs. Most notably area 7 bit 7 for a "1".
Carl
Jun 02, 2009 | Panasonic KX T7436 Corded Phone KX-T7436
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Panasonic kx-t7030
    Jan 10, 2009 | Panasonic KX-T7030 Corded Phone
    Panasonic White Kx-t7030 Phone System Telephone Kxt Logo
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
