Question about Uniden TRU9585 Cordless Phone
Phone out of range - Uniden TRU9585 Cordless Phone
Phone says out of range
If it says out of range ... you will have to move closer to the transceiver. If you once could use your phone from whereever you now find it is out of range, your batteries are nearing the end of their useful life.
May 14, 2010 | Lands Phones
All of the phones say out of range
check if phone base is unplugged from either phone or power lines at both ends.
Jul 17, 2009 | Panasonic KX-TG1033S Cordless Phone
Phone is frozen
Hello everyone I have great news. To clear the out of range error code just remove the handset from the base, hold down the end key and the # key at the same time. It will say deregistered completed place the phone on the base. Your problem is solved. Enjoy!!!!!!!!!!!!!!!
Apr 18, 2008 | Lands Phones
Help with MD781 phone problem
on the phone that says, 'out of range' you need to select MENU then scroll down to the option that says REGISTER and select that. Then go to your BASE UNIT and push and hold the PAGE button until the 'bad' phone synch's up again. .... I called into motorola support and they stepped me through this.
Mar 03, 2008 | Motorola Mobility MD781 Phone...
Range extender for cordless phone
Ours behave similarly. The solution is to position the "base" (one connected to the phone lkine physically) in the center of the home so that the limited range can reach the remote phones at the periphery.
These phones operate at 1.9GHz. At that microwave frequency radio signals do not penetrate walls and floors very well. 2.4 GHz phones suffer increased "path loss" and are no better. The solution for any of these microwave phones is more transmitter power, which is illegal.
900 mHz phones actually work better because at 900 MHz nature offers less signal path loss", but try to find them in stores! For the same transmitter power level a 900MHz phones will have noticeably greater range.
The 1.9GHz D.E.C.T. phones also operate differently from other types of cordless phones and I believe that also contributes to dropped calls and the phone's inability to ring when a call arrives. At the fringe of its range you can see how it struggles to establish a link. Once established it will work well and then simply drop the call when you least expect. I am not a fan of the DECT phones, but they do not interfere with 2.4 GHz wireless routers, etc.
Jan 02, 2008 | Panasonic KX-TGA101S Cordless Handset
Out of range
I have a Radio Shack 2.4ghz cordless phone system and sometimes the handsets will show "Out of range".
My Solution that works for me.
Unplug the power cord and telephone line to the base for about 30 seconds. This seems to reset the base. Then plug everything back and you should be ok.
ET Sherman
Oct 07, 2007 | Panasonic KX-T7730 Corded Phone
Out of range. people call me and i dont hear the phone ring, when i try calling out, screen says "out of range"
I found this on Motorola's website and it did the trick for me. https://cordless.custhelp.com/cgi-bin/cordless.cfg/php/enduser/std_adp.php?p_faqid=13471&p_sid=9pUDwsGi Good Luck, Chris
Jun 14, 2007 | Motorola Mobility MD7081 Cordless Phone
Open Questions:
Uniden TRU9585 Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
