Question about KitchenAid KUDS35FXSS Dishwasher
Need reset code for kitchen aid dishwasher model KUDS35fXSS dishwasher fills the immediately goes into drain cycle
  • 1314 Answers
SOURCE: Replacing detergent dispenser on Kitchen Aid Model KUDI24SEAL3 Dishwasher
send me an email at b4829@yahoo.com and ill send inst
Posted on Mar 19, 2008
  • 530 Answers
SOURCE: Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Posted on Apr 14, 2009
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
SOURCE: My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
Kitchen Aid KUDI02FRSS2 - I have the same problem and called Kitchen Aid (Whirlpool). They originally told me the control panel needed to self-program and that I needed to let it run through one complete cycle before it would lock in the program. When this didn't work they told me the unit has water temperature sensors in it that controls the length of wash depending on the incoming water temperature. When I told them the house water temperature was borderline scalding they said they could send a repair tech out for $75 just to come to the house. I told them to forget it and could buy the control panel for $80 bucks and install it myself for free. I had a previous K/A dishwasher that ran for 30 years without a problem. This one was a problem from day one. Never again - Whirlpool or K/A
Posted on Aug 27, 2009
  • 246 Answers
SOURCE: Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Posted on Feb 25, 2010
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
Kitchen aid dishwasher
The washer is filled up with water because it is at float level. So basically same water to clean again and again. You will have to remove kick panel at the bottom front for access to the pump and drain hose.
Apr 24, 2013 | Dishwashers
KUDS35FXss is dripping from the bottom of the door
Bad door seal drain plug not knocked out of garbage disposal other would be main seal at pump u can take bottom dishwasher off and watch were coming from if it's at door then door seal if still has water when done then check drain and disposal drain plug hope this helps
Feb 21, 2013 | KitchenAid 24 In. Stainless Steel...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
SA 660 SMEG dishwasher constantly filling....
this can be water draining from your sink into the dishwasher via the drain pipe, assuming the drain pipe goes to a spigot on the sink trap.
take the drain hose up as high as possible in a swan neck to prevent this.
Jul 17, 2008 | Dishwashers
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
KitchenAid KUDS35FXSS Dishwasher Logo
287 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
