Question about Simmons SD5K 7Piece Electronic Drum Kit
Almost no sound from my sd5k console
I can hear sound but the volume won't go any louder than a whisper
I can hardly hear the sound from this 600 watt system when it's on. why or how do i fix this?
Hi, Check you speakers out. Plug them in another amp. If speakers are good the 600 watts system is to blame. Have is repaired by a qualified techy. Good luck.
Jul 27, 2015 | Music
One key sounds louder than the others
Hi, This is very likely to be a dirty key contact.
If the loud key is not touch sensitive or by turning the touch off, if all the keys are the same volume then this points to a dirty key contact.
All the best, Chris the Fader.
Mar 08, 2014 | Casio Privia Keyboard Case
Need insrtuction manual
go to:www.music123.com/.../DV040_PDF_Copy_5E45EE25-FEDB-48EC.
Feb 02, 2012 | Simmons SD5K 7Piece Electronic Drum Kit
I seem to always get a static sound out of my Line 6 Spider Iii below 9 o'clock on the volume knob. Not only is it staticy, but the volume jumps all around and goes from whisper quite 1 second to house...
It sounds like you have a dirty pot (the volume control). Unfortunately the only way to clean the pot is to open the amp up and try to spray some Servisol Super 10 in through the small opening in the pot case.
WARNING: Tube amps contain lethal voltages even when unplugged! If you are not an experienced service engineer then take it to someone who is! It is a pretty common task in guitar amps so shouldn't cost too much.
Sep 10, 2011 | Line 6 Bogner Spider Iii Valve Tube Combo...
The Simmons SD5K keeps spontaneously playing songs, even when all I want to do is play my own stuff with the metronome! I turn on the metronome, set the speed, hit the pads a few times, and the music...
Press the "click" button and then set the tempo you want, press the "click" button again this will stop the metronimoe but is also sets the tempo in memory. The next time you press the "click" button it will be ready to go.
Anytime you press the tempo + or - it thinks you are trying to use the "Tap Tempo Function".
Jun 07, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
SD5K Drum module NOT saving user defined voices.
Possibly has a Lithium battery in it that is depleted that maintains the saved data.
Jun 02, 2011 | Simmons SD5K 7Piece Electronic Drum Kit
Fender ultra deluxe amp volume max out a number 7 volume control. will not get any louder
It is likely that the amp is flat topped at the 7 setting. When the amp is producing the maximum voltage output it is capable of, that is ALL you can get out of it... The numbers on the dial mean NOTHING and are only relative. If you have high output guitars you might find the maximum might only be 3 on the dial for example...
If you need it louder, get a bigger amp and speakers. You should ALSO get a sound meter and follow OSHA guidelines for sound exposure... I know several musicians that now are nearly deaf because of being exposed to high sound levels... their music careers are now gone as they can no longer hear well enough. You need to protect your hearing for the long term. Great musicians don't need loud, but quality and inovation in their music.
Jan 07, 2011 | Music
I've got a Honey Laquer(tweed) deluxe.Bought it new about three years ago. While it's powered up, there's a whine sound coming out, almost like a mid frequency feedback that doesn't change with the volume...
I suspect a bypass capacitor for the preamp section has failed. It needs to go to the shop and be tested with an oscilloscope to pinpoint the problem.
DO make sure the feedback is NOT from something you have plugged into it... make sure it is there with NO input cable plugged in. Often external devices can introduce ground loops an noise like this. Lamp dimmers (even stage lighting dimmers) can be a source of interference.
The sound you hear MAY not be the full loudness as the oscillation MAY be above your hearing range. This COULD cause overheating and damage so get it fixed before using.
Oct 04, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Simmons SD5K 7Piece Electronic Drum Kit Logo
20 people viewed this question
Top Simmons Music Experts
Vito Vacirca Jr.
Vernon Taylor
The Audio Lab
Are you a Simmons Music Expert? Answer questions, earn points and help others
