Question about New Home HF-2022
Dash board switches1991 chevy pickup dashboard switches
Its blinking when i turn it on doesnt do nothing what to do?
This sewing machine has circuit boards, switches, and inlet harnesses as well as CPU circuit board boxes. There is a way to find where the problem is by a step by step method. Take your sewing machine to a qualified repairman.
Nov 27, 2015 | Singer 7426 Mechanical Sewing Machine
Singer confidence sewing machine won't pickup bobbin thread
Make sure the bobbin is inserted into the bobbin case spinning the correct direction and rethread and try.
Oct 03, 2014 | Singer Confidence 7469 Mechanical Sewing...
Husqvarna 500 sewing machine won't turn on
yes, it's possible. also could be the on/off switch, or the power cord.
Jan 24, 2014 | Husqvarna Sewing Machines
Bottom thread will not be pickup
There is loose thread hanging from the lower bobbin, isn't there?
Dec 12, 2013 | Necchi 4595 Mechanical Sewing Machine
My kenmore sewing machine model 11607090 won't pickup the bobbin thread
try changing the needle
try rethreading the machine top & make sure to use
every thread guide
make sure the bobbin is turned the right way in the bobbin case
it's also possible that the machine may need to be checked to see
if there is a timing problem
Oct 15, 2012 | Kenmore 11206 / 11306 / 11506 / 11606
My kenmore sewing machine won't pickup the bobbin thread
if you've tried changing the needle & tryed rethreading the machine
then it's possible that the machine need to have the timing checked
My Bernina 1230 won't shut off. I need to unplug it each time.
I agree about the on & off switch, it could be going out or have a short in it
Apr 05, 2012 | Bernina Sewing Machines
No power
The circuit board is on the very bottom of your machine. Tilt it back and the black square you see with the phillips head screw is a cover that can be removed. (Make sure your machine is unplugged first) Once the cover is removed you'll see the board, gently move it out slightly and check to see if the 2 plugs that plug into the rear of the board are tight. One of those plugs is the motor wiring. Also check the switch, if it's bad the machine won't turn on. There is no fuse in this machine. One last issue is the bobbin shut off on the right side of the machine. It's located directly underneath the bobbin winding spindle. When you put the board back in the machine make sure you align the post from the winder shut off to the metal "flange" that hits the switch on the circuit board. That switch and shaft alignment could cause the machine not to run if it's assembled in a "pinched" position but you'd still have power to the light bulb. If the switch is good and the connections are good and the bobbin switch is aligned properly and your sure the cord is sending electricity through to the machine, then you power board is bad.
Oct 11, 2009 | Husqvarna Sewing Machines
My Husqvarna Viking 980 continues to sew when I take my foot off the petal. Sometimes the stich get very tight when this occurs. Could this be the foot petal or is my circuit board going out?
I have never seen it be the circuit board, always is the foot control switch. I dont understand the stitch getting tight though. And yes, it could be the circuit board.
Mar 07, 2009 | Husqvarna Viking 1
New Home HF-2022 Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
