Question about Whirlpool LER7646E Dryer
This dryer will not heat up. Continuity on coils is okay.
I have checked continuity all over the dryer. The coils look good and the switches(to the best of my knowledge) are okay also.
I pulled the coil out from the bottom. There is another connection above that. This connection has nothing on the other side. In other words..... It looks as if it should have another coil, but doesn't.
  • 20 Answers
Check your fuses,one runs it and the other dries it
Posted on Jun 22, 2009
I have an amana electric dryer. Will not heat up. i checked thermostat for continuity it is good. i checked the two thermal fuses for continuity they are good. I even jumped a wire accross all three...
Hi pitsburg69...
you have probably already checked some of these...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Sep 04, 2011 | Amana Dryers
LER4634PQ0 The heating coil looks intact but is black?? No heat and checked the thermo fuse and that was okay. Do I need a new heating coil? Also the timer does not turn at all, whatever dial we set...
Hi rmine 1999....
Here is a few things to check.
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Jun 01, 2011 | Whirlpool LER4634J Electric Dryer
Electric Kenmore Dryer - - runs okay but there is no heat for drying. Dryer is approx. 2 years old.
Check your Wiring
Check the blower motor to make sure it is not faulty, also check the blower fan blade to make sure it is not broken or plugged with lint.
Check the Door Switch.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
This is a FREE answer, Please rate me
Jan 15, 2011 | Kenmore Dryers
Kenmore model 110.62952100 does not heat up but runs good. What should I check first?
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Dec 04, 2010 | Kenmore Dryers
Heats but not good
Check your Wiring
Oct 13, 2010 | Estate TEDS840JQ Electric Dryer
No heat
Sounds like you're pretty good at this. Next you should check the two heat limiter switches that live near the elements. (They're no larger than an average radish.) They should check "closed", or have continuity. (Pull the connectors off first. Reconnect them using contact grease. Important for these and other connectors.) After you've done that, follow the wires to the motor. The reason the heating element wires go to the motor is because there is a switch that resides on the shaft end of the motor where the centrifugal switch is. This centrifugal switch has two purposes: 1) it cuts out the starter winding of the motor after the motor has reached almost full speed and 2) it turns ON the heater coils after the motor has reached almost full speed (for safety). Check this switch for burning/melting, which might not be evident until you remove it. Check continuity by moving the centrifugal collar on the shaft with your finger to simulate a running motor. (Disconnect the heater coil wires from the terminals first. And -- I am assuming you've UNPLUGGED the dryer by now!!) Lastly check for power coming out of your timer. A contact set might be welded or fried. Good luck.
Feb 26, 2010 | Kenmore Dryers
Drye runs but does not get warm
Sounds like your heating coil is faulty.
Unplug the dryer, remove the back of the dryer.
Locate the air tube going from the blower to the drum.
Normally inside the air tube is where you will find the heating coil and thermostats.
Remove the wires from the heating coil...and check with a continuity meter across the two terminals...you should read continuity across the terminals, if you do not read continuity across the terminals then the heater coil is faulty.
Good luck,
I hope this helps
Oct 05, 2009 | Whirlpool Dryers
Won't heat
You did not say if you had an Electric or Gas dryer.
My expertise is with Electric Dryers.
If you have an Electric Dryer then you problem is probably the heating coil or thermostats.
Unplug the dryer.
To check them remove the back of the dryer, locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and thermostats.
Remove the wires from the heating coil. Use a continuity meter on the two terminals to check for continuity...if you do not show continuity, then the heater coil is probably faulty.
Good luck,
I hope this helps
Oct 05, 2009 | Kenmore Dryers
I REPALCED THE TIMER CONTROL AND MY DRYER WILL
Always check to make sure you have power at the unit. If power is present and you replaced the timer control there is something else causing your unit not to fire up. I will assume your unit is an electric dryer. Before you check anything inside the dryer make sure your power cord is unplugged. Then check the door switch for continuity. If the door switch test okay then check the thermal fuse located on the blower assembly. Remove one lead and test for continuity, if okay then check the upper limit on the heating box. Again, this is a continuity check and again remove one of the leads before you check for continuity.
Sep 15, 2009 | Dryers
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
