Question about KitchenAid KUDR01TJ Dishwasher
Lower seal on dishwasher leaks
It might be the whole door seal is bad
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
vcx
Posted on Sep 29, 2010
How can I tell if the seals are bad and not the whole water pump on a 05 envoy. Before I purchase the whole pump and all I need is the seals?
You can't buy a water pump seal by itself. Gasket, yes. Seal, no. If you're going to go to the trouble to remove it to replace a gasket, you replace the whole thing
Aug 10, 2017 | Cars & Trucks
Refigerator door doesn't stay sealed shut
Check the seal condition for any damage, crack and etc. Ensure you check the whole seal. Clean the surface (seal and the contact) from any dirt/oil and etc.
Sep 24, 2007 | Sub-Zero 650 / O Bottom Freezer...
Defrost water leaking inside the fridge
are u sure its defrost water? the water does not usually go from the freezer to the fridge as if its a top bottom door , the doors have seals. which leads me to my next point. Perhaps u have a door with bad seals and thus the moister and air get in and cause condensation and water build up? if u place a dollar bill inbetween the door and frame then close it and try to pull the dollar out. it should have a slight tug and not be easy to pull out? keep moving the dollar around the whole door to look for a bad seal? or try to feel for loss air escaping with ur hand
Mar 16, 2015 | Whirlpool Refrigerators
Dishwasher leaking at lower door seal
Possible that the door seal has failed and there is leak when the pressure spraying takes place. Please check the seal and replace, click for tips to replace: door seal
Jan 02, 2013 | Dishwashers
I've bought a Defy Autodry tumble dryer, but the black "rubber" on the door keeps coming out, which then pushes the door open, and the machine then automatically stopped. Can i just replace...
A TUBE OF CONTACT CEMENT WORKS WONDERS ON THE SEALING RUBBER - JUST FOLLOW THE INSTRUCTIONS ON THE TUBE . IF ITS GOOD ENOUGH FOR DOOR SEALS IN THE AUTOMOTIVE INDUSTRY ITS GOOD ENOUGH TO HOLD YOUR DOOR SEAL IN PLACE - GOOD LUCK.
Jul 26, 2011 | Dryers
Moisture buildup on exterior of freezer door
some moisture build up is normal,its called a condensation path,but the whole door may indicate a bad seal or terribly high humidity if it only does this during humid days
Jun 10, 2011 | Kenmore Side by Side Refrigerator
I have water leak out of our front loader, it leaks out rite in the middle from the bottom of the door. I am not sure if it is from the small hole in the door or if it because of a bad seal. The rubber...
the wire ring just keeps the seal in place,, make sure the bottom of the door glass is clean,, if so look at the seal and see if it is pushed in alittle around the bottom,,you can take a hair dryer and heat it up while pulling it back out ,, ( just the lip part) if that doesnt work you will need to replace the whole gasket
Jan 24, 2011 | LG WM-2277HW Front Load Washer
Door seal between fridge & freezer is hot is this normal ?
No, there is a heater in the seal of the doors to keep the doors from icing up, if it is hot to the touch then the heaters are going bad and must be replaced. You can replace it yourself by removing the door seals, and then removing the heating element that runs the whole door. When you do this make sure that the unit is unplugged.
May 17, 2010 | Kenmore 53092 / 53094 Side by Side...
How to find and replace a freeezer door seal
on many models, it is not possible to fit a replace,ent door seal - they are foamed into the door and to replace the seal means replacing the whole door
Aug 27, 2008 | Freezers
KitchenAid KUDR01TJ Dishwasher Logo
102 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
