Question about Baby Care
Non contour bottles - Baby Care
FUNCTION PROBLEM SC681-19 FOR RICHO SP C830DN
This is an error code for the RFID which is the toner bottle chip on the the toner bottles. I would suggest you check the toner cartridges for any damaged or disconnected chips, have you changed to non ricoh toners as this can sometimes cause a problem. Check each bottle if you have any old empty bottles insert one of these into corresponding colour slot and you can then see which bottle is causing the error. Failing this the board will need to be changed. I have had errors on non ricoh bottles. you can also vac out the slot to clear spilt toner. hope this helps
Feb 24, 2014 | Ricoh Aficio 2035 Copier
I had a new coil pack installed on my 99 ford contoure and now I have not much power and when I stop the rpm fall to almost 0 and wants to die
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Jan 18, 2014 | Ford Contour Cars & Trucks
Timing belt broke on 1996 Contour; sepentine belt replaced only 3 yrs. ago - related?
Not at all. Your serpentine belt is in the same area as the timing belt, however is NOT related to the function of your timing belt.
If you have a 4 cylinder 2.0, then you have little to worry. Most of the contour 4 cylinder engines are supposed to be "non-interference"... which basically means that if the timing belt breaks, then there is not much risk of your contour's engine to have internal damage!
So... Replace the timing belt, and you should be back on the road within 1 day.
Feb 01, 2010 | 1996 Ford Contour
How to change the timing belt in 1996 ford contour gl
I know this is old, but that guy is wrong... the zetec is a non-interference engine... meaning the the valves cannot come in contact with the pistons.
Dec 14, 2009 | 1996 Ford Contour
96 ford contour poer steering fluid
Open the hood and look at the very back corner (passenger side) of the engine compartment, there will be a white plastic bottle with a black thread on lid. This is where the power steering fluid goes. The bottle has marks on the side of it to indicate how far to fill if needed.
Apr 05, 2009 | 1996 Ford Contour
2000 contour
for 98 contour issue. TSB 98-21-14 not covered by warranty
This TSB article is being republished in its entirety to include the 1999 Cougar . ISSUE: The ignition key may be difficult to insert or remove and/or key chimes may sound with the ignition key removed and driver's door open on some vehicles. This may be caused by internal design characteristics in the ignition lock cylinder increasing insertion/removal efforts which may allow the lock cylinder to stick.
ACTION: Install a revised ignition lock cylinder. The revised ignition lock cylinder should reduce the possibility of high insertion/removal efforts and ensure proper chime function. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
  1. Verify customer concern.
  2. Observe the ignition lock cylinder as the key is removed. If the lock cylinder snaps outward to the non-depressed position and the chimes stop sounding, continue to Step 3. If it does not snap outward, replace the ignition lock cylinder with the appropriate cylinder by referring to the Parts Block in this article.
  3. Insert and remove the ignition key from the lock cylinder. If binding or high efforts are encountered, replace the ignition lock cylinder.
  4. From the Parts Block, select a lock cylinder with a part number suffix identical to the center character of the key code of the vehicle. The suffix must match the center key code character to maintain a single key system.
  5. Install the replacement lock cylinder, by referring to the 1998 Contour/Mystique Workshop Manual, Section 211-05 or the 1999 Cougar Workshop Manual, Section 211-04. NOTE: KEYS INCLUDED WITH NEW IGNITION LOCK CYLINDERS ARE CUT FOR THE IGNITION ONLY. IN ORDER FOR THE KEYS TO FUNCTION IN THE DOOR LOCKS, THE KEYS MUST BE CUT TO THE DOOR CODE OF THE ORIGINAL LOCKSET. THE KEY CODE WILL CHANGE UPON INSTALLATION OF THE REPLACEMENT LOCK CYLINDER (FIGURE 1).
    Figure 1 - Article 98-21-14
    NOTE: ADVISE THE CUSTOMER TO DISCARD ALL KEYS THAT WERE CUT TO THE ORIGINAL IGNITION LOCK CYLINDER.
  6. Record the new key code on the repair order and provide to the customer. Advise the customer to record the new key code in a permanent location and to discard all references to the original key code. NOTE: REPLACEMENT IGNITION LOCK CYLINDERS ARE SHIPPED WITH NON-PASSIVE ANTI-THEFT SYSTEM (PATS) KEYS. IF THE VEHICLE IS EQUIPPED WITH PATS, OBTAIN TWO (2) ROTUNDA KEY BLANKS (OR OTHER FORD AUTHORIZED BLANKS, SUCH AS: ILCO, STRATTEC, CURTIS, HUF, OR VALEO) AND CUT TO THE REVISED KEY CODE. USE OF OTHER UNAUTHORIZED KEYS MAY CAUSE ERRATIC OPERATION OF THE PATS SYSTEM.
  7. Program PATS keys using one of the two following methods:
(1) For vehicles with Integrated PATS (IPATS), function built into the Powertrain Control Module (PCM) and built beginning:
  • 2/2/98 Kansas City (Contour/Mystique)
  • 2/16/98 Mexico (Contour/Mystique)
  • All 1999 Cougars
Using the New Generation Star (NGS) Tester equipped with Service card (green) level 3.0 or higher:
  1. From NGS menu, select:
    • Service Bay Functions
    • PCM
    • Enter Security Access (10 minute delay)
    • Ignition Key-Code-Erase
  2. Disconnect Data Link Connector (DLC).
  3. Cycle the first non-programmed key in the ignition to run position for at least 3 seconds and then turn to the off position.
  4. Cycle the second non-programmed key in the ignition to run position. The theft indicator should prove out for 3 seconds.
  5. Verify the vehicle will now start using both keys.
(2) For Contours/Mystiques with Stand Alone PATS and built before:
  • 2/16/98 Mexico
Using the New Generation Star (NGS) Tester equipped with Service card (green) level 1.0 or higher:
    • PATS
    • Ignition Key-Code-Erase (this process may take up to 8 minutes to complete )
  2. Disconnect DLC.
  3. Cycle first unprogrammed key in the ignition to run position. First key will program and allow vehicle to start.
  4. Again cycle first programmed key to run position. Within 15 seconds, remove original key and turn new unprogrammed key to run position. The theft indicator should prove out for 2 seconds. New key will start vehicle.
  5. Repeat this process for additional key programming. NOTE: THE FOLLOWING SHOULD BE NOTED FOR THE PART NUMBER BLOCK:
    • Part Number suffix will match center character in key code
    • Logo on key is Ford for Contour models
    • Logo on key is Mercury for Mystique and Cougar models
PART NUMBER PART NAME F5RZ-11582-A Ignition Lock Cylinder (Contour) F5RZ-11582-B Ignition Lock Cylinder (Contour) F5RZ-11582-C Ignition Lock Cylinder (Contour) F5RZ-11582-D Ignition Lock Cylinder (Contour) F5RZ-11582-E Ignition Lock Cylinder (Contour) F5RY-11582-A Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-B Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-C Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-D Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-E Ignition Lock Cylinder (Mystique, Cougar)
Mar 09, 2009 | 2000 Ford Contour
Ford contour, radiator cap,where is it
there will be a plastic bottle for coolant fill it to the full mark , the radiator will fill itself.
Mar 02, 2009 | 1998 Ford Contour
97 ford contour V-6 cranks won't run
Open the air cleaner and look down into the intake while someone else is turning over the car. Is their gas or gasoline vapor being put into the engine or not?   If yes then I take a philips screw driver on the end of a spark plug wire while some one else is turning it over, to see if it has any spark.  I woudl gues 90% or all non start but cranking problems are going to be in one of these two areas.
Dec 28, 2008 | 1997 Ford Contour
1997 ford contour
this is for 98, but may apply if yours is late 97 build.
Article No.
98-21-14
  • IGNITION SWITCH - HIGH EFFORT IGNITION KEY INSERTION/REMOVAL AND/OR KEY CHIMES SOUND WITH DOOR OPEN AND IGNITION KEY REMOVED
Publication Date: OCTOBER 15, 1998
FORD: 1998 CONTOUR LINCOLN-MERCURY: 1998 MYSTIQUE
1999 COUGAR
SERVICE PROCEDURE
  • All 1999 Cougars
    • PCM
  • 2/16/98 Mexico
    • PATS
  2. Disconnect DLC.
Aug 13, 2008 | 1997 Ford Contour
Baby Care Logo
236 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
