Question about AOC CT720G 17" CRT Monitor
CRT EV730 Monitor Just went out won't power won't do any thing
Borugh a new Gateway Computer in 04 came with CRT 17' monitor have't had any problem with it went to get on computer and no responds from monitor theres no power or anything check all conntoin still noththing should I get it fix and if so where im located in MI
    Scholar:
  • 124 Answers
Check the color of the pluggie that goes into the back of your monitor, it is most likely either blue or white. Find a friend who has the same color plug and borrow their monitor for a few minutes. If theirs works; your monitor has **** out. If theirs does not work then your video card (on-board or add-on card) has **** out and you'll have to have a new card added to your system.
Posted on Jun 23, 2009
When I turn the monitor on it has a red green blue screen
It would appear that the monitor is not getting a signal from the computer. You should try to power down the monitor and remove the power plug and let it cycle. Also, check the VGA cable connections to make sure they are connected properly.
If this does not cause any change, you can try to connect it to a different computer and/or connect another monitor to the computer you are using this Gateway monitor on if you can do that.
Let's start see if we can get this problem solved.
Brian
Feb 07, 2011 | Gateway EV 700 17" CRT Monitor
Where is the headphone jack for the gateway EV730
You have to connect your headphones at the line out of the audio card at your desktop. It's the green jack with 3.5mm diameter at the back of your case. If the place that you have the desktop is not conventional for plug and unplug the headphones, I suggest you using an extender like this one. In case you use a speaker set there must be a headphones output either on one of the speakers or at the control unit.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 04, 2010 | Gateway EV 730 17 in.CRT Conventional...
GATEWAY 2275 LCD MONITOR WENT OUT, WHEN PLUGGED
This could be due to a bad power supply inside the monitor witch is replaceable for like $25 bucks all you got to do is unscrew off the back undo a few cables and put in the new supply.
I hope this helps you in the repaire process if its under warrenty please seek warrenty guidlines.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Gateway FPD2275W LCD Monitor
I have a new Dell Studio 540 computer and I'd like to hook it up to my Gateway EV910 monitor. I connected everything correctly. The monitor has power, turns on to the monitor self test screen where it...
You dont need to install a driver for the monitor. The power save mode message appears when the monitor is not able to get a signal from the computer. Make sure the the vga/blue cable is securely plugged to the back of the pc.
note: Inspect the back of your studio. You may have two blue ports where you can connect the monitor, if you do, connect the monitor to the one at the bottom half of the computer.
Jan 02, 2009 | Gateway EV 910 19" CRT Monitor
Desk top computer crt monitor
Time to buy a new monitor, especially if you are still running a CRT monitor.
There is nothing you can do without taking the monitor to a repair shop, and that would cost more than the value of the monitor.
Jul 10, 2008 | Gateway FPD2275W LCD Monitor
Monitor went blank
Let's try to isolate the problem:
-If possible try both monitors on a different computer.
-does the computer makes any sound when you turn it on?... do you get any image at all when you turn it on?
Jun 28, 2008 | Gateway 310S (2900621) PC Desktop
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
White horizontal lines of static on monitor
Can you try reducing your monitor refresh rate to a lower frequency, or the lowest frequency.
Apr 10, 2008 | HP Pavilion F1703 17" LCD Monitor
Gateway EV730
Hello Jahodi
Happy Holidays
WHat kind of lines has it? from any program or it is directly from your monitor? may be is your monitor that has problems with horizontal lines, this happend sometimes.
try changing to the refresh rate to 75, or the size of the screen. to 1024 x 768
Dec 21, 2007 | Gateway 500 CS PC Desktop
Monitor is blank, power is on
it was on after it went blank & again on means there was a loose connect as it came back on. but now that loose contact has got permanent due to print breack or track open. the problem is in 1 monitor to computer connector not properly connectec. 2 crt base loose 3 track open or print in power supply. 4 if it is ok check for horizontal section print or loose. hope this will help good luck. 1 power supply print b
Sep 28, 2007 | Gateway FPD2275W LCD Monitor
AOC CT720G 17" CRT Monitor Logo
97 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
