Question about G-Technology 120GB G-Drive Mini Triple 120 GB FireWire 400 Hard Drive
G Drive Mini not mounting but can see in system profiler/firewire
PowerBook G4
My other hard drives are mounting but not my G Drive Mini 120 GB. So it is not firewire issue. My drive hums and the light turns on but doesn't mount. I do see the drive in system profiler/firewire.
??? My experiences with portable drives in the past not mouanting have lead to being told that I need to try external power even though this product is designed to not need external power.
Also curious if I need to "update the firmware" for my hard drive to mount?
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Failure to mount on desktop
Iomega which is now a thing of the past were renowned for their fragility It may well have died
Posted on May 24, 2007
joecoolvette
  • 5660 Answers
SOURCE: Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Posted on Jul 22, 2009
rommelalilin
  • 2178 Answers
SOURCE: hey, i just ended up
Connect the power adapter source for the drive and verify it powers up. The connect the USB.
Posted on Oct 31, 2010
  • 79 Answers
SOURCE: drivers wont mount. tried to mount them on a Star
When you turn the drive on, does the indicator lamp flash once and then is dark? If so, that indicates a defective hard drive. When you mounted the drive in the Star Tech drive reader, did it spin up? If not, that would confirm a defective drive. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Posted on Jan 26, 2011
I am trying to switch on my g4 notebook. And am presented with a folder icon bearing alternately a finder icon and ? Any ideas?
Your mac cannot find an operating system. Re-install the operating system using the 2 discs Apple gave you. If that don't work, then you need a new hard drive. 2.5" 120 GB laptop hard drive IDE/ATA are the specs you need. If it says SATA, then you got the wrong hard drive.
Sep 05, 2010 | Apple PowerBook G4 Mac Notebook
Cant find the disc on my powerbook g4
STart up your G4 using the OS disc for leopard, but instead of reinstalling the system, go to the menu at the top of the screen and Launch Disk Utility.
You may need to remount your hard drive. The disk utitliy can do this for you. Then it should appear in the disk utillity window. Then you should be able to install the OS and away you go!
May 10, 2010 | Apple PowerBook G4 Mac Notebook
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
MAC G4 won't boot - Blue screen appears
Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
Mar 30, 2009 | Apple eMac G4 Desktop
WD 320GB portable Hard drive not recognized by my powerbook G4
NTFS file system on Hard drive .
http://www.macyourself.com/2012/03/11/how-to-format-a-drive-for-mac-and-pc-compatibility/
Nov 26, 2017 | Western Digital My Book Essential Edition...
80 gb hard drive from apple pro book does not work
Try using Disk Utility to mount the drive. This can be found in the Utilities folder within the main applications folder. Launch Disk utility and see if the drive comes up in the list of drives down the left hand side. I presume that the hard drive in the enclosure is spinning. You can normally hear it, and feel a constant light vibration.
May 29, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
May 23, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
G-Technology 120GB G-Drive Mini Triple 120 GB FireWire 400 Hard Drive Logo
620 people viewed this question
Top G-Technology Computers & Internet Experts
General Systems...
dbgreenfield
Level 1 Expert
Julie Clark
Julie Clark
Are you a G-Technology Computer and Internet Expert? Answer questions, earn points and help others
