Question about Dryers
Where are tongtel dryers made? - Dryers
I need a working code for my universal remote (audio sonic, jlr6002) for my tongtel tv Help!
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.....
http://electro-medical.blogspot.com/
Apr 19, 2016 | Universal Televison & Video
Why is my tongtel portable air conditioner leaking water on the floor
It actually means it is working very efficiently. The cold side is condensing water because the humidity is high.
See if there is a tank to empty, or a stopcock or screw to attach a tube to a bucket. You could also adjust it so it doesn't go quite so cold.
Jan 13, 2016 | Heating & Cooling
Why do you have to put salt in my tongtel dishwasher?
Dishwasher salt is used to prevent hard water deposits from spotting dishes and prevents the build up of hard water deposits that can damage the machine.
May 12, 2014 | Asko 1385 Dishwasher
Alarm clock tongtel mw-1256
Hi Christina sorry I don't have a manual but need one....did you ever find one?
Regards Larry
May 07, 2014 | Home
TONGTEL PRESSURE COOKER
Take a look here for pressure cooker instruction manuals:
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Mar 25, 2014 | Nesco 6qt Electric Pressure Cooker Pc6-25...
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
