Burners won't light on brivis buffalo - Heating & Cooling
4 Suggested Answers
SOURCE: Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Posted on Nov 08, 2009
  • 12650 Answers
SOURCE: Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
Posted on May 31, 2010
SOURCE: Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Posted on Jun 12, 2010
Mu brivis buffalo 20 will not start
whats the code the little red led light blinks out ??
or no light then its got no power
May 26, 2017 | Heating & Cooling
I have a Brivis Buffalo 85, pilot light is on main burners will not ignite when turned on? It seems like gas isnt allowed to bar which turns on main burners
Usually a thermocouple or similar device is employed to allow fuel to flow once the unit sees that there is sufficient heat to ignite the fuel. Otherwise it can be a fuel valve that "sees" an unusual flow of gas which sets off the safety.
May 07, 2014 | Honeywell Programmable Thermostat Heater
How to turn on the brivis buffalo 52
Refer the user manual given below to setup your Brivis Buffalo 52 and start operating it:
Brivis_Manual
May 28, 2012 | Heating & Cooling
I have a Brivis buffalo 26 unit...the heating is on but it's blowing cold air the pilot doesn't seem to be light but I don't know how to relight it!
Try adjusting your thermostat, contact point possibly melt and welded by electric sparks. Replace thermostat control if contact won't get open.
Sep 02, 2011 | Heating & Cooling
When main gas valve opens to start burners the gas pauses then ignites with a high volume woof.The pilot flame looks a little small could this be the issue. This unit is Brivis Buffalo year 1988 model...
The problem is called "Delayed Ignition". This can be caused by burner & pilot obstructions (dust, lint and/or pet hair) and needs to be thoroughly cleaned. At 23 years old, I'm surprised the unit is still in service.
Hope this helped you to troubleshoot and solve the problem.
Apr 28, 2011 | Heating & Cooling
May 31, 2010 | Heating & Cooling
Hi. Brivis Buffalo not igniting
Okay,
first and for most do not light burners manually, if that chamber is filling up with gas and you light that sucker you risk the chance of causing an explosion or a blow back that will burn you. What you need to address is
-are the burners clean
-is there proper gas entering the gas valve
-is there proper gas to the manifold
-is the flue product being exhausted properly
-is my exchanger sooted up
-is my gas valve working properly
pm me for walk through steps
May 27, 2017 | Heating & Cooling
Sep 22, 2009 | Heating & Cooling
Jun 11, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
