Question about Toshiba 50HP95 50 in. Plasma Television
Toshiba plasma no picture white vertical lines
My Toshiba 50 in plasma screen has no picture, good voice about 6 white vertical lines appear occasionally. please advise if this is something that can be fixed ?
  • 179 Answers
SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
Posted on Nov 28, 2007
SOURCE: Toshiba 42wp46p
just repaired one of these with the same fault. at the bottom of the plasma panel you will see a row of ribbon connectors, on the back of the ribbon connectors are some surface mount components. resolder these components on the offending connector, clean the contacts on the ribbon connector and reconnect. unfortunately getting to the connectors is quite a job, so give yourself plenty of time. if this doesn't cure the fault then the poor connection is on the plasma panel which you cannot repair, the only option then would be to replace the panel.
Posted on Apr 09, 2008
  • 128 Answers
SOURCE: Vertical Flashing Lines on Toshiba 42HP84 Plasma 42"
troubleshooting PCB's of certain electronic units require advanced technical skills. no service manual of any source would provide specific solutions. the best you can get are schematic diagrams. if your field of expertise is not related to electronics, i suggest you let the technicians handle the problem for you. every shop have their repair cost qoutations. just be sure to ask for warranty of their repair. goodluck!
Posted on Oct 24, 2008
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Posted on Feb 05, 2010
SOURCE: 50" Toshiba Plasma screen is flashing with flickering sound
www.tacp.toshiba.com/tacpassets-images/.../42hp66_om_e.pdf
http://www.fixdevice.com/smanuals/file/31149.html
Above, download these Service manuals, it will show you how to troubleshoot, and identify what board to repair change.
Posted on May 05, 2010
Estimated cost for fixing Tobshiba LEDTV? Model#50L3400U. Colorful vertical lines, left hand side but more towards the middle. Lines appear on all imputs and are constant.Lines appear over the menu.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 19, 2016 | Toshiba 50 Class 1080p 120Hz LED Smart HD...
How do I fix a vertical line on a 50 inch nec plasma monitor
Jun 28, 2016 | NEC Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
My toshiba 50 inch plasma tv model 50hp66 powers on but has no sound or picture
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 18, 2015 | Toshiba 50HP66 50 in. Plasma Television
Why my toshiba plasma tv have vertical white lines?
is this on all inputs? just want to be sure to eliminate any source or input issues. Are all cable connectors between source & TV good.Possibly MAIN (I/O PCB)
could be connecting cables between power & X/Y pcbs, cables between X?Y pcbs & buffers, cable between buffer pcbs & panel, possibly buffer pcbs,
May 21, 2014 | Toshiba 50HP66 50 in. Plasma Television
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Phillips 50 inch Plasma
    Philips 50 inch plasma tv no video but has sound
    Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
    Green line on each side of the plasma display.
    Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
    Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
    Parallel vertical lines through left side of Panasonic Plasma tv
    This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
    May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
    White lines accross top of screen on our 27 inch Toshiba,
    lcd or plasma.
    are the lines solid or blurred. do they have sharp edges.
    You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
    May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
    Toshiba 50HP95 50 in. Plasma Television Logo
    15 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
