Question about Bosch Nexxt WTMC 3300 Electric Dryer
What size an type motor goes in a bosch nexxt dryer wtmc3300
ttdesignbilt
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
I had the same problem and figured if the lint sensor is clogged, covered or otherwise gummed up with lint, dirt, hair, etc then this will continue to happen regardless of wether the lint trap is clean.
So I took my compressor and blew out the slot where the trap slides into...stuff flew everywhere (so watch your eyes or wear goggles). I then vaccumed it up and did it again... and again and again each time loads of stuff came out. Once nothing blew out I loaded the dryer and have not had the problem since...
This makes sense right? so if you can try this solution.
Posted on Jan 24, 2009
SOURCE: Bosch Nexxt Electric dryer tumbling but not
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
Posted on Apr 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: The dryer (Bosch Nexxt 500) makes a loud grinding
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Posted on Sep 26, 2009
SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
Posted on Dec 28, 2009
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
My Bosch Nexxt 500 dryer stopped heating. All other functions work fine except heat. I've checked continuity on heating element & overtemp breaker- both OK. What else could be the problem? Fuse?
CONSIDER THIS
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER
Maybe you don''t have power to both legs of your receptacle. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Dec 14, 2015 | Bosch Nexxt 500 Dryer
Bosch nexxt 800 series wtmc8520uc not working
How do you get to the motor mount? Where is it located?
Jan 22, 2012 | Bosch Nexxt WTMC8320US Electric Dryer
My Bosch Dryer Model nexxt WTMC3300 will not run. The Start switch indicating light turns on and blinks as it should. The lint light flashes a few times then goes out. But when I push the start switch,...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
May 01, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
My Bosch Dryer is not heating, we have cleaned all the lint from front and from hose in back of dryer, still no heat.
Check your voltage. Take a volt meter and make sure it is set on 250 or higher volts. All electric dryers needs to have 220 volts going to them. One 110 goes to the motor and one goes to the heating elements. If you are only getting 110 volts only one side then it is your electrical problem. Check your breaker or fuses.
Apr 30, 2011 | Bosch Nexxt 500 Dryer
My bosch nexxt wtmc3300 dryer won't start.... cleaned the lint filter, took the back off and vacuumed it out, everything is lightimg up but when i hit the start button, nothing.... please help, getting...
Hello, Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch, but with the most common there are two thermostat's/switches
which could be reset, plus a no reset hi-limit ( on the lint housing )... i.e. macmarkus_15.jpg ...which cannot be reset, but the hi-limit is the one related to heating...located on the heater housing and the other (emergency shut off/belt switch) is by the motor shown below.
Anyway,
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor I alluded to which will prevent it to start in the event it was tripped for whatever reason.
This is the most likely scenario in my opinion based on your post...but again it depends on your model.
This will require you to remove the back panel again though. Once you've remove the rear panel, It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
Since you`ve already taken the back of the dryer off before to gain access you should have no problem.
Either Scenario I alluded to will require the removal of that panel so let me know if you require further assistance to do this.
The other would be resetting the hi-limit cut out, You can see through the back vent opening when the vent tube is removed ( cannot be removed without removing rear panel the first time, but if attached a certain way can be done each time after ) and then by pushing the red button in...shown below.
i.e.
Keep me posted how you make out or if anything is not clear or if your model is completely different...some have line fuses at the back.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dryer wtmc3300 was overheating and now wont start up. Only makes a clicking noise. The time indicator lights up and thats it.
Dec 01, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dryer nexxt, motor runs but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
hlg
Jan 24, 2010 | Bosch Nexxt 500 Dryer
My Bosch dryer spins but does not heat up. It is
Most likely it is the thermal switch that is located near the heating elements. This switch is the device that regulates the temperature. When it goes bad, it remains open usually. Short of a burned heating element wire, this is probably it. The only other thing it could be is the switch on the end of the motor. This switch turns on the heating element only if the motor runs. Check that too. Good luck.
Nov 28, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
The dryer (Bosch Nexxt 500) makes a loud grinding noise when rotating. Any idea what this may be?
Sep 26, 2009 | Bosch Nexxt 500 Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
26 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
