Question about Car Audio & Video
Wiring diagram for Bose 802 speakers - Car Audio & Video
dunnbiker
  • 8546 Answers
SOURCE: Hi. I would like to connect a Bose controller
Tech data sheet with diagrams:
http://www.bose.com/pdf/professional/802III_techdata.pdf
In a nutshell, the controller would go between any preamp Stereo OUTput and a dedicated amplifier INPUT. You really don't have much choice in the matter. The 802's and their controller are part of an inseperable system.
The Bose 802/901 family uses full-range speakers instead of traditional woofer/tweeter combinations, so they compensate for the response limitations at the extreme frequencies by using severe electronic modification of the program material. Hence, they are a system, functionally inseparable, but the results are outstanding. Consequently, they need a dedicated amplifier so they alone get the processing provided by their electronic component.
I don't have any data on your mixer/amp but if you can't insert the conroller logically between the mixer and its amps then you'll have to get separate dedicated amplification for the 802's, with the controller between the mixer and that amp.
Posted on May 17, 2009
TwinTurboZ
  • 78 Answers
SOURCE: 2005 chevy silverado stereo wiring diagram
Are you trying to install a new stereo? If so will need to re-wire all your speakers because of the bose system.
And if im not mistaken your year truck might need a really expensive harness to install the radio. Here is a link to it.
http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?tp=3486
You should look into this too! http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?
Posted on May 22, 2009
co7196
  • 3433 Answers
SOURCE: need help finding a wire diagram for a bose stereo in 2000 jimmy
speakers aren't fused, You have a wiring problem
Posted on Jun 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: do I need special speaker wires to hook up bose
It comes with special connectors - not necessarily special wire.
You will need the Lifestyle Cables.
c35cb24.jpg Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 01, 2009
Grubhead
  • 5056 Answers
SOURCE: Hi, I have lost the base in one of my bose 802
If you have switched speakers to confirm that that speaker is faulty and not your amp, it's a question of opening up the speaker and looking for obvious damage. If none then find the bass driver and remove one connection to it. Then with a 1.5 volt battery connect the + to the plus of the bass driver and the - to the other terminal. ONLY FOR A SPLIT SECONED! If the bass unit works it should pop and you should see the cone move. If it doesn't either the wire from the speaker has come away from the terminal point (bad soldering) or the coil is open circuit (new bass unit I'm afraid). If it does pop it's something on the crossover that's faulty. Check for bad soldering first.
Posted on Jun 25, 2010
Bose repair manual
The driver that rattles has a worn voice coil and needs to be replaced.
Aug 23, 2014 | Bose Panaray 802 Iii Loudspeaker
How to rewire Bose 802 speaker ?
Register (free) at http://www.hifiengine.com/ You can download a service manual for those speakers at that site.
Aug 18, 2014 | Bose Panaray 802 Iii Loudspeaker
2007 Nissan Altima Stereo Wiring Diagram for Bose Navigation
None are actually color coded. The schematic has the wire colors on it next to the wire.
May 01, 2014 | 2007 Nissan Altima 3.5 Sedan
Wiring diagram for bose 28060
Infiniti QX56 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Purple
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Green/White
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: To the right of the steering column behind the BCM.
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Blue/Black
Left Rear Speaker Positive Wire (+): Gray
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Red/Blue
Jul 08, 2012 | Cars & Trucks
Hi. I would like to connect a Bose controller between a pair of Bose 802 speakers and a Studiomaster Powerhouse 300 MIXER/AMP. The diagram on the top of the controller shows the amplifier connected just...
May 17, 2009 | Bose Audio Players & Recorders
Bose 802 C series II to Yamaha rxv 459 Amp
In a nutshell, the controller would go between a preamp Stereo OUTput and a dedicated amplifier INPUT. You can't use Bose 901 or 802 EQ in a multichannel setup without separate amps for the Bose speakers.
In a vanilla stereo configuration you would just put the controller/EQ into a Tape Monitor loop but multichannel sound and digital sources won't work that way.
You should be able to draw off the (assumed) Front L&R channel preamp signal from the MD/CD-R or DVD-R Audio Out (REC) jacks (*). Run that to the Preamp In (or whatever it's labeled on the Bose EQ/Controller). DO NOT run a return RCA pair back to the Receiver as Bose-processed signals will not play well with non-Bose speakers. (*) Run the Output of the Bose EQ/Controller to a powerful separate amp for the Bose 802/901's. I use two channels on a Carver multichannel AV-406 amp but a stand-alone Carver MT-200T also works well. A good clean 100 watts/channel should suffice at home.
* If possible, choose the recorder loop you are NOT using for something else. If you're using the MD/CD-R or DVD-R Audio OUT for a recording device just get some RCA splitters to share the Stereo signal between the Bose and the device at the same time. However, once you select monitoring of that recorder two things will likely happen - 1) you'll lose the Bose and anything digital in the receiver will be disabled.
It's the nature of the digital beast that analog monitoring gets in the way of DSP.
Of course, if anyone who reads this has a receiver with individual analog Audio Outputs for the various 5.1 channels (as I do), the solution would be to draw off the Front L&R channels to the Bose EQ and downstream amplifier and the rest would be the same but without Recorder Loop limitations.
Apr 28, 2009 | Bose 901 VI Main / Stereo Speaker
Hafler power amp has one side out. Would like local repair.Series 9300.Approx.10-15 years old.Not used much.Second time to blow.Runs 4, 8om speakers including 2 bose 802,s (no bose controller or eq in...
just discovered same problem with my Hafler DH-200...right channel out but no obvious problems inside (no loose/burned wires, components, etc). Driven by Hafler pre-amp, but definitely power amp problem.
Sep 03, 2008 | Audio Players & Recorders
Bose speakers 800
I' ve just sold 2 pairs of 800's. The buyer(who once owned a music business) used an 802 controller to test them. He said that any bose eq would do the job with no problems.
Jan 01, 2008 | Yamaha Emx88s Powered PA Mixer System
'05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Oct 15, 2007 | Audiovox BA200 Car Subwoofer
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
