Question about Blendtec Blenders
Blendtec burning smell - Blendtec Blenders
Get a manual for blendtec ES3
i have blendtec blender model ES3 they have problem always showing overload?
Apr 06, 2012 | Blendtec Extra Carafe / Jar for the Total...
Does anyone know how to reset a Blendtec ICB-3 to factory settings?
ust removing all power from the machine for 15 secs or more should reset it.You can contact Blendtec here, Not a solution I know sorry. The manual is here http://www.blendtec.com/Resources/A3-31E-BHMV/Connoisseur%20Manual.pdf
you can contact them here
http://www.blendtec.com/contactus.aspx
Jan 03, 2011 | Blenders
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
Jun 30, 2010 | Blendtec Extra Carafe / Jar for the Total...
How to change the blade
You can't. The Jars have perfectly balanced blades that cannot be changed. A replacement jar from Blendtec is cheaper than a replacement blade assembly from other manufacturers. 1-800-253-6383 is the customer service number.
Jun 04, 2010 | Blendtec Smoother Work Top Blender
The rubber washer in the jar burned up
Happens occasionally. Call blendtec and they can hook you up if it is still under warranty. 801-222-0888.
May 19, 2010 | Blendtec Extra Carafe / Jar for the Total...
ICB-3 Blendtec unit is getting power but will not turn on
check thermal fuse internally , one time blown fuse. need a test meter to check this component , can be bought @ Radio Shack apx $ 8.00us
Mar 13, 2010 | Blendtec ABC Work Top Blender
BLENDTEC BLENDER WONT WORK WATCH DOG TIME OUT?
That is a motor issue, you need to contact Blendtec customer service. They will let you know if it is still under warranty. 1-800253-6383.
Oct 31, 2009 | Blendtec HP-611-FLP / HP-621-FLP Work Top...
Blendtec blender jug split
I wouldn't fix the jar, just buy a new one. A crack, though rare, could possibly harbor bacteria. You could try using heat and melting it, but it wouldn't work as well. Your jar may still be under warranty, call Blendtec at 801-222-0888
Feb 24, 2009 | Blendtec Extra Carafe / Jar for the Total...
Lost manual
Call 1-800-blendtec and they can email you a manual. I have a pdf version if you need it.
Aug 22, 2007 | Blendtec BD4 Blender
Blenders Logo
161 people viewed this question
Top Blendtec Blenders Experts
eyecam
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
