Question about HP Vs17 17" LCD Flat Panel Monitor
Nothing happens when I press the power button on HP vs17 lcd monitor.
    Scholar:
  • 119 Answers
You might want to check and make sure that your power is plugged in [obviusly], next check to make sure that your data cale is properly connected or that your computer isnt in stand-by mode or hibernation. When your monitor doesnt receive data to display it goes into 'power saving mode' which simply is this 'Wake me up when you have something you want me to show'. SO try and unplug your your AC power for a bit and while doing that double check that your data cables are 'thumbs up' then reconnect your AC and try powering up. If all this doesnt work, and you're using a graphics card to send input to your monitor, check your graphics card, or try and listen for any fan noises just to make sure your computer has life...
Posted on Jun 22, 2009
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My monitor is flashing different colors... it wont start up
chanel_luv_u, Could be possible internal SMPS/CCFL inverter power supply problem. If the PC is ok with different "known-good" monitor connected to PC, then vs17 monitor will need some work done on it. Do some reading here first for some clues!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flatpanel-disolay-blackout-solution/ The first place I would look at on ANY ccfl back-lit lcd monitor that starts doing "very strange things" would be the units "switch-mode-power-supply/CCFL inverter circuit". Try YOUTUBE for video clips of DIY lcd monitor repair to see if unit can be fixed for less than $6 in parts. Keep this in mind though, Your vs17 isn't any different than any other ccfl back-lit lcd monitor in it's basic design and operation. Do some reading of fixya LCD monitor technicians profiles for more info. Let us know what plans you have after you do your research. Bye for now. 12fixlouie
Jun 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp vs17 monitor is glitching
Look for bad caps with bulging tops in the power supply section. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My Computer boots and montitor says Going to sleep and flashes VGA : NO signal and goes off
Check under "Power Options" of the control panel of Windows that "Turn off Monitor" is set to "Never" Also check under the advanced tab of "Power options" that "When I press the sleep button on my computer" its set to "Do Nothing"
This will most likely solve your problem. the sleep button may be stuck on the keyboard causing the pc to quickly go into sleep mode
Nov 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs15 monitor Flickers then blacks out.
Hello
This monitor has 5 capacitors in the power supply that age prematurely. I can repair this for $50.00 +parts + shipping. Or you can take it to a local repairperson.
Jul 28, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Not working.
Did you install the software for the monitor? If you do not have the disc, You can download the driver here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=447382&lc=en&cc=us&dlc=en&submit.y=7&submit.x=8&lang=en&cc=us
If you have any further problems,let me know. Thank You for using Fix ya!
Aug 23, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Pavilion Vs17 LCD MOnitor
an answer to this problem would be great because mine does the same thing...like blinks but monitor wont come on.
Jun 23, 2008 | HP Pavilion F1703 17" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
251 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
