Question about Galaxy Radios DX- 88HL Base CB Radio
Why does my galaxy 99 and every time i key the mic i blow a fuse. what is wrong with my radio?
  • Mike Charette Oct 07, 2016
    Jeremy Elliott, if it were the the protection diode the radio wouldn,t even turn on.
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Could be your final
Posted on Aug 09, 2014
I'm a cb tech in Dodge City Alabama and it sounds to me like you may have blown your protection diode which is a pretty easy fix. Just make sure you put at least a 7 to 10 amp fuse inline once it is repaired. You can ask at about any CB shop for a D4 Cap replacement
Posted on Oct 07, 2016
steve132003
  • 98 Answers
SOURCE: I have a Galaxy DX 55v cb radio...The problem I am
sounds like somebody has tampered inside it , knocking out alignments. There is a resistor and very small transistor near back that controls transmit+receive. I don't know which number resistor it is on your model. I know where it is on Uniden/Cobra models(recommend Cobra 25ltd) Take to Cb shop or service repair place. They may help you. Just buy you a Cobra for cheaper and go with it.
Posted on May 01, 2011
SOURCE: fuse blows when I key the microphone. Why does this happen?
what size fuse u put back in it 7amp what u should have put back in it i think
Posted on Feb 21, 2009
  • 39 Answers
SOURCE: Powers up, recieves fine, breaksup on transmit Galaxy 949
Check the wiring on the mic plug sounds like you have a loose wire or one thats about to break off.Good luck.....Dan
Posted on Apr 04, 2009
anymhz
  • 500 Answers
SOURCE: Galaxy 95T
check SWR's check to make sure ALL coax connectors are tight. and if still doing it. may be loose connection in board. but the export style radios go crazy like that when coax is loose or have bad grounds. due to there floating ground circuit design. there not the same as a cobra were its case is ground.
Posted on Dec 08, 2009
anymhz
  • 500 Answers
SOURCE: galaxy dx94hp...stays keyed up all the time
check the mic connector internally its probably touching something in side.
Posted on Feb 26, 2011
Inline fuse blows when mic is keyed and talking
either wrong size fuse or wires are touching inside mike when keyed
Sep 09, 2013 | Radio Shack Radio Communications
My radio is a Galaxy DX 98. It squeals when I key up
change "MIC" to a factory,or turn back Mic gain. Mic can short out or may have too much gain(power mics). Use standard dead Mic that was designed for radio. If that does not help,it may be inside radio, wires on MIC connectors need soldered again(make sure they don't touch th eothers.
Apr 23, 2011 | Radio Communications
My galaxy dx 66v when i turn it on it stays keyed all the time even without mic pluged in..........and when i turn my talkback switch on all it does is squeal.need help
make sure the mic connector board is not touching anything inside. if it is not.. below it is a diode for the TX/RX.. replace it with 2 914 diodes and should work again.. 99% of the time..
Mar 27, 2011 | Radio Communications
Put another **** on 29 ltd and lost key up and receive but it still lights up. What you thank is wrong. 5 different mics, all work in my other radios. I heard something chatter and it would not tx or rx...
Check to make sure that there is noting shorting out inside of the radio. some mic plugs can turn from overtighting the mic connector.. also check the pins they may be broke or compressed too much and won't make connection to any mic.. Pin 1 is ground and pin 4 is rx.. take a jumper wire across those and see if you get rx back. same for tx pin 3.. jumper pin 1 and 3 should have a key up. pin 2 is your of course audio. these should be first things to check. cobras unidens and galaxys, connex, genlee etc. are wired the same. midlands and radioshacks ge are different. so make sure your mic is wired for a cobra or galaxy also.. any mic will work on any radio. as long as is it wired to it correctly....
Dec 15, 2010 | Radio Communications
Radio stuck in transmit meter needle is slammed all the way to the right as soon as you turn unit on
Have you recently changed mics ? if so it is wired wrong, if not I would check for a shorted wire in the mic connector or the mic itself.
May 25, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Fuse blows when I key the microphone. Why does this happen?
i am pretty sure something came loose or a connection went bad, now something is shorting, possibly to the chassis. if you think you know how to open it up and work on it than do it. Or take it to a tech and have them look at it. it should be a real quick, real simple fix.
Dec 04, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy Radios DX- 88HL Base CB Radio Logo
197 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
