Question about Samsung UN55B8000 55 in. LCD HDTV
I replaced the main board and power supply board and my samsung still turns on and off?
  • 2326 Answers
SOURCE: Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to jah2mil@hotmail.com
Posted on Jan 05, 2009
Cool_dud 09
  • 206 Answers
SOURCE: power supply board
Hai,
Please check on here....you will find it out!
Posted on Aug 23, 2009
SOURCE: I have a Samsung LNT4665FX with screen problems. I
To solve this type of problem, you need a piece of white chalk. Draw a line around the area where the set is at. Call a priest - and lay the poor thing to rest!!!! This isn't the first time Samsung has "dropped" junk onto its' customers. Their dvd players also had problems with their DSP I.C.s that would over heat and cause the video playbacks to "break up". Don't waste any more time or money on the product!!!!!
Posted on May 18, 2010
bshldn
  • 736 Answers
SOURCE: I have Samsung UN46B8000XFXZA LED TV. After power
Yes based on your testing it appears that the power supply is at fault solely and you can opt to attempt a repair or replace it altogether. Unfortunately you will not be certain that the main board does not also need to be replaced until you have repaired the power supply.
Posted on Feb 05, 2011
SOURCE: Samsung power supply & IP board BN44-00264B &
For anyone else with this problem...I ended up getting a replacement transformer from ebay and swapping it out myself.
You have to remove the back panel of the TV, unplug the board from the harness going to it, unscrew the board (both via the set of screws going directly through the board and the set going through the plastic piece on the opposite side that, as far as I could tell, the board is glued to). This plastic piece (running the length of the board) has receptacles for the backlight bulbs, so be gentle getting it in and out. Don't forget the screw in the middle of the board.
De-soldering was a little tricky. My soldering skills are not great, so maybe it was me. But it certainly seemed to be a little challenging to get it all out. Having so many terminals probably didn't help (a capacitor would have been easier). Eventually though, I did get it out. Soldering in a new one was easy. Be sure to check continuity between the terminals of the new part and other parts of the board using the traces as a guide once you're done.
After that, simply re-install the board and put all hardware back in. Like I said before, be sure you re-engage the receptacles of all the backlight bulbs by pushing down at each notch on that plastic part of the board.
Hope this helps someone else...
Posted on Dec 19, 2011
I have a Samsung TV that will not turn on.
You have diagnosed the fault yourself. The main board of your TV is defective and needs to be replaced.
Good Luck.
Oct 02, 2017 | Samsung Televison & Video
Hi have Samsung tv(UN40H5203AFXZA) Version:TD01. It doesn't turn on just red light blinking, no sound/ pics.How can I know if it's main board or power supply board and what should I buy? Thank you
Hello Anas,
These failure could be a combination of the power supply and the main board failing.
I would suggest to replace both boards or if you are able to measure the voltages from the power supply and verify that the power supply is working, then you should only replace the main board.
Let me know if you require further assistance.
Search results for UN40H5203AFXZA
Jun 11, 2017 | Samsung Televison & Video
Television Samsung Model UN46EH5000F
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Dec 23, 2016 | Samsung Un46eh5000fxza un46eh5000 46 1080p...
I have a faulty Samsung LCD TV and i would like help identifying the part of the TV that needs to be replaced.
like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 12, 2016 | Samsung Televison & Video
Samsung 32" LCD TV
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 01, 2016 | Samsung Televison & Video
My samsung tv turns on and off repeatedly on its own. I replaced the power supply board with no luck. What should I try next?
Hi Jonathan,
Turning on and turning off is the joint function of the power supply and the main board. You have changed the power supply, so the only thing left to replace is the main board.
Good luck.
May 03, 2016 | Samsung PN51D6500 3D Plasma TV
My samsung wont turn on already replace power supply cap
If it does not turn on despite power supply change, it has to be the main board responsible if you get power led on.
Dec 22, 2013 | Samsung Televison & Video
I have a Samsung HLN437W DLP TV I turn it on and in about a minute there is no picture or sound and you have to turn it off you have to unplug it
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Dec 23, 2011 | Samsung HLN437W 43" Rear Projection HDTV
Goes off & comes back on.. now stays off Samsung model LN46A540P2
This could be 2 things, a main board or a power supply. I have replaced many main control boards on samsungs and it solved the problem. But sometimes it could be the power supply. You will need to test the voltages on the power supply to rule out the power supply being bad.
Jul 11, 2010 | Samsung 46 in. LCD HDTV
Samsung plasma sp-r4232
Remove the power supply cable to Y Main board, check Vs on power supply board when you turn on tv.
1. If you have normal Vs, replace the Y Main board. If still not work, replace the Logic board.
2. If you don't have normal Vs when you try to turn on your tv, just replace the Power Supply board.
Jan 01, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung UN55B8000 55 in. LCD HDTV Logo
67 people viewed this question
Henry  Thomas
Henry Thomas
