97cc equals how much horsepower - Office Equipment & Supplies
What is the horsepower of Mitsubishi 4D30 Engine?
the engine is 3298 cc turbo diesel with a 95ps @3500 rpm or 23kg er meter @ 1800 rpm
the 95 ps translates as 70 kw and that equals to 93.8 hp
Nov 10, 2017 | Mitsubishi Cars & Trucks
What is the rule of thumb for computing the capacity of horsepower of air conditioner in terms of area, e.g. square meters
Horsepower does not necessarily matter. Horsepower is not computed to capacity. Amounts of btu/ heat removal, is measured capacity. 12,000btus which equals 1 ton of cooling will cool a maximum of 500 sqft depending on the heat load. Obviously a brand new home with updated insulation vs a closed in lanai with a wall of windows...you get the idea
Jul 22, 2017 | Heating & Cooling
One horse power equal how many cc count in every motorcycle?/
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://spicerparts.com/calculators/horsepower-torque-calculator
Jun 05, 2017 | Miscellaneous
What is the motor hp?
Please see below courtesy of engineeringtoolbox.com
Electrical power is in general rated in watt (W) or horsepower (HP). A horsepower is a unit of power equal to 746 watts or 33000 lb ft per minute (or 550 lb ft per second).
A watt is equal to the power produced by a current of 1 amp across the potential difference of 1 volt. A watt is 1/746 of 1 horsepower.
Even if the watt is the base unit of electrical power, it is common to rate motor power in either horsepower or kilowatts.
Power in Watts
Direct Current Electric power supply to a direct current (DC) motor:
PkW = ?m U I / 1000 (1)
where
PkW = power (kW)
?m = motor efficiency
U = voltage (V)
I = current (A, amps)
Electric power supply to a alternating current (AC) motor:
Single Phase PkW = ?m U I PF / 1000 (1b)
where
PF = Power Factor
Two Phase Four Wire PkW = ?m 2 U I PF / 1000 (1c)
Three Phase PkW = ?m 1.73 U I PF / 1000 (1d)
Power in Horsepower
Horse power can be expressed as:
Php = PkW / 0.746 (2)
or
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
where
Php = horsepower (hp)
Feb 03, 2016 | Boating
What is the horse power?
A unit of measurement for power. Equal to the ability to move approximately 550 pounds. Horsepower dictionary definition horsepower defined Here's a link to explain further.
Jun 02, 2015 | Cars & Trucks
Hi, if you are referring to a particular vehicle you need to provide make model year and engine option. If you are asking what a horsepower is it is defined as
horsepower[ ?h?rs?pou(-?)r ] NOUNa unit of power equal to 550 foot-pounds per second (745.7 watts).Powered by OxfordDictionaries · © Oxford University Press
What is the average power consumption (watts)? What is the start-up power consumption?
Sir / madam
Horsepower (HP) is the name of several units of measurement of power. The most common definitions equal between 735.5 and 750 watts. Horsepower was originally defined to compare the output of steam engines with the power of a draft horses... In refrigerator the unit use is horsepower(HP) 1 HP = 750 watts
Jun 21, 2011 | Refrigerators
One horsepower is how many ton? I want to know how many tons of refrigerant is equivalent to one horsepower capacity of a cooling system.
1 to 1...
1 hp. equals 1 ton or 12,000 BTU's....at least in round numbers...
this can vary just a bit depending on the combination of condensers and evaporators...
heatman101
May 25, 2010 | Carrier 30HXC096 Indoor Water-Cooled Screw...
13 people viewed this question
jasbo
jasbo
