Question about Sharp Cv-10mh 10000 Btu Portable Air Conditioner Ac Dehumidifier W/remote
PARTS CV-10MH SHARP PORTABLE TYPE AIR CONDITIONER
3 Suggested Answers
  • 25 Answers
SOURCE: My CV-13NH portable type room
If its blowing air, but not cold, the compressor isn't engaging. There are many different possibilities on this.
Bad compressor, unit out of gas, bad run capacitor, etc, all could cause this, even a bad control panel.
Hope its something simple.
Greg.
Posted on Aug 18, 2008
  • 64 Answers
SOURCE: I have a Sharp portable
Most of these devices have condensate pans that need to be emptied. these can and will shutoff the unit when they become full. i would start to look low in the front maybe behind a removable panel. good luck.
Posted on Jun 26, 2011
How do I remove plastic housing from Sharp CV-P10MX portable air conditioner to clean dust from inside.
It should be clipped on with a type "S" clip. If there are no screws visible, gently work all sides and pull towards you.
Apr 29, 2014 | Sharp CVP10MX cvp10mx 9 500 btu portable...
SHARP Portable Air Conditioner keeps stopping.
Make sure the condenser coil is clean and the exhaust duct is clean/not crimped or blocked.
Aug 28, 2013 | Sharp Cv-p10pc 10000 Btu Portable Air...
Hello, I have a Sharp CV-10MH that will run fine for about 2 minutes and then shut off and flash all of the front panel lights. I have done all maintenance possible -- clean filters, drained the lines,...
The problem you describe is a mechanical one. The compressor is overheated and stop to prodect from burn out. You need to check the freon charge, and the condenser fan if they are ok,
Also the thermal relay have to be check if it clik stable.
Jul 29, 2011 | Heating & Cooling
My conditioner Sharp CV-P12LX shuts down after 10 min of operation. A noise is heard in the plug reset switch as well
If you have to reset the plug then its pulling to many amps. If you don't know what else is connected to that particular line (in your breaker box) you might consider using another outlet. Increasing amps. of breaker may not be advisable without consulting an electrician.
Jan 24, 2011 | Sharp CV-P09LX Portable Air Conditioner
I have a Sharp portable a/c model CV-10MH. I drain it regularly and keep the filter screens clean. The other day it started throwing out warm air then just shut down. It does this often now. Any ideas?...
not a expert just trying to help,, sounds like you have coils in the back of the unit cloged up with dust,, take outside and spray some water and clorox mixed on the coils and clead good then rinse of with water,, hope this help
Sep 01, 2009 | Heating & Cooling
I love my Sharp CV-10MH Portable Air Conditioner but I'm afraid to use it. After a while it starts to make a noise I'd describe as a CLATTER or a RATTLE. Before I use it again I must know that this is not...
I had the same issue of filling up after a couple hours but mine started making some pretty loud noises as well just before shutting itself down and lighting all three lights. The top drain valve would no longer work and the only way I could drain it was through the bottom (gravity) drain valve. I took the unit apart and found that the simple water pump that is used for draining and the evaporating process had lost the thin filter screen on the bottom and the screen became lodged in the impeller of the pump preventing it from spinning. I removed the worn and broken plastic screen, carefully pushed the impeller back up on the shaft until it bottomed out, and cleaned all the built up sediment off the entire pump. After reassembling everything, the ac unit runs like new again and the noise is completely gone. Cost? $0
I imagine you can just order a new pump from sharp and save the time and effort of cleaning the pump.
Hope this helps!
Aug 03, 2009 | Sharp Heating & Cooling
My CV-13NH portable type room air conditioner won't blow cool air
Greg.
Aug 18, 2008 | Sharp Heating & Cooling
Sharp Cv-10mh 10000 Btu Portable Air Conditioner Ac Dehumidifier W/remote Logo
Top Sharp Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
