Question about Venturer Televison & Video
Venturer plv 7118
After 2 minutes lose pixture, have sound only. Have tried disxonnexting all cables and rexonnextjng. Nothung seems to work.
2 Suggested Answers
SOURCE: i have a venturer tv, no sound?
I found an audio amp IC and indicated on the top of the chips is CHMC S0723. It should have cross reference can be found in ECG semi-conductor guide or NTE ICs manual. The pin#12 is the Vcc in 12VDC, pin#6 & #7 are audio input L&R.
Other solution is just hook an RCA cord right into its audio out of this set to your receiver and it will works.
Posted on Jun 08, 2011
Where can I get a user manual and remote for my venturer PLV 71180523 19" TV with DVD Bob J
Try Venturer website itself.For the onwner manual,if ur tv model still in the market place.U will able to download it for free.If it is not look for their phone 1-800... call their customer service pay them a fee.They'll send it out to u.Try website like Remotes.com to buy the tv original remote or a very closed clone compatible one.
Sep 02, 2011 | Televison & Video
I cannot power up my Sanyo PLV-70 projector. I have changed the power cable but the box is still dead, no sign of any power input.
try another wall outlet if that dosent work try a nother cord, than if it still wont respond it could be a blowed fuse or a bad power bord.
Jun 04, 2011 | Sanyo PLV 70 Multimedia Projector
I can not get a picture on my venturer plv 76176 TV.
There is a whole lot of points to check up but start from the power supply and move up to the main board, the display drivers. check the convergence IC's, check if any capacitors have damaged , check if there is sound but only absence of picture.
Does the backlight work?
please confirm.
Sep 02, 2010 | Televison & Video
Where is the fuel emergency cut off valve located
it's in the trunk. inside the quarter panel. look to the right or to the left. it should have a sign that states fuel shut off switch.
May 14, 2010 | 1997 Chevrolet Venture
I would like to connect my Sanyo PLV-Z2 project to a DVD player with HDMI output in order to higer quality. I used a HDMI->DVI cable and connected DVI to Z2. I set the input 2 as RGB-HDCP. However it does...
I have the same unit (2 of them actually.) I have spent a lot of time on this very issue. The problem is that although the unit is "supposed" to be HDCP (digital copy protection) compatible, it is not fully. I've found that with some DVD players it will work for a minute or two and then go black, and with others, it will flash on and off, and with some it will never do anything but black. I have only found 2 ways around this. 1 is to use a computer (which does not use the HDCP) windows Vista/windows7 might have the same problems, but XP/2000/Linux work perfectly. The other solution that worked was to use a Playstation3 which seems to work perfectly with it playing DVDs and BlueRays.
Feb 23, 2009 | Sanyo PLV-Z2 Multimedia Projector
I have a venturer tv, no sound?
Feb 09, 2009 | Venturer PLV36220S1 22 in. LCD TV
Loss of picture
Yes, it is the projector.
Take the filter out and vaccum it, take the lamp out and use compressed air to clean the dust away.
Be carefull witt the air thoug! keep it a bit away from the projector when u cleand the dust away, to close and you can make big mamages inside it.
And, remeber to keep the filter as cleas as possible, i clean min every 2,5-3 monthes.
Good luck
Dec 06, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sony Tuner KV-20TS27 loses signal
Either that of your tuner block is acting up. Most Sonys of this production year uses a tuner block that requires 33VDC tuning supply. It has been known for this zener to fail or the capacitor parallel to it. At times, it could just be the tuner block itself.
Should you venture a DIY, it would be to your advantage to have access to a service manual or at the very least a schematic diagram with voltage readings.. It further requires familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Should you be uncomfortable going this route, then perhaps your best bet would be to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Televison & Video
Venturer PLV 1615 15 inch LCD TV
The problem is in the power supply. If I had a schematic I could fix it myself. Can anyone tell me where I can get a schematic? I sent several emails to Venturer support but they don't reply. Benjamin
Mar 26, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
