Question about Garden
I have a bv 1800 super blower vac weedeater I need for the settings for the screws on the carburator there are two any info I would be thankful.
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: My MCCulloch super airstream IV blower has only
Iam going to refer you to the Zama carburetor tune-up and adjusting guide for all this instruction.
http://www.zamacarb.com/tipspage.html
Posted on Dec 10, 2010
What is the carb ajt for my weedeater bv 2000
A carb jet size change would not be likely as a fix. You may need to clean the carb and the jet(s) though
Oct 04, 2014 | Garden
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
What is the spark plug gap for weedeater bv 1850
You shouldn't need to set the gap on plugs when you buy them for handheld equipment. It should be close enough straight from the factory. You can find replacement spark plugs at PartsBuggy.com.
Oct 12, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Need "L" and "H" setting on carb mixture screws
Lightly seat the screws all the way in....then back them out about 1 and 1/2 turns. From there here is how to do the final Zama diaghragm carburetor adjustments.
Oct 30, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
How do i adjust the carburator on homelite weedeater
It has two screws or at least it should. One with the letter L next to it and the other with the letter H next to it. Turn both in lightly until they seat. Then turn the L screw out 1 1/4 turns and the H screw out 3/4 turn. This should get the unit running unless you have other problems. then fine tuning may be required after you get it running. If it bogs out when throttled turn the L screw out another 1/16 of a turn. Then if it won't rev like it should turn the H screw in 1/16th of a turn.
If this doesn't work then you'll probably need a carburetor kit and tune up.
Good luck
skidooer
Oct 03, 2009 | Homelite Consumer Products Backpack...
How to hook up a carburator on a weedeater with a primer bulb
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 18, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
