Question about Sceptre X32GV-Komodo 32 in. LCD Television
AFter we turn the tv on it goes off and on every few seconds. the power doesn't go off just the picture & sound.
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
Dec 11, 2010 | LG 42LG30 42 in. LCD HDTV
The picture on my TV goes black after few seconds
Hi my name is Roety,
I can help you with your issue ,
Sounds like a lamp going bad
No model listed makes it hard to guess here
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KLV-32M1 LCD TV switches off/on
in this situation autoshutt off in few seconds no sounds and pictures. you have to check the secondary power supply. check all capacitors. budged capacitors can make shutt off sytem. capacitors blown on top due to hot pressure inside tv.
Jul 08, 2009 | Televison & Video
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sceptre X32GV-Komodo 32 in. LCD Television Logo
37 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
