Question about Home
Jacuzzi col error code - Home
My jacuzzi J340 2002 is flashing the code FLO2. What happens if I continue to run the tub with this code displayed? Thanks to anyone that can help me.
flow switch error code, malfunctioning closed. do not use until you have rectified the error. use a jacuzzi authorized repairman/woman.
Jan 01, 2017 | Jacuzzi Home
Does the pump on my motor have a reset button
There are no reset buttons on motors.
How do you turn the pump on/off ?
Nov 17, 2014 | Jacuzzi Luxura, 530 Whirlpool w/ Integral...
--- code keeps coming on
this is the nature of the error code displayed.
(---) =Unknown water temperature. (Displays when first powered up after refill).
RodUS Parts Center888-521-6183
Oct 19, 2012 | Jacuzzi Pool & Spa
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
What do the arrows on the jacuzzi luxura 530 control
Arrows on the control indicate up/down temperature or on/off on the air control.
Jan 13, 2011 | Jacuzzi Luxura, 530 Whirlpool w/ Integral...
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
I have problem in how to call the matrix using fuction
I don think u are in the right way to program the Matrix in C language, i found a lot of syntax error in your code, but nevermind i had correct it for u. Maybe still need a little correction for your own. Following code:
void matrix(int a[2][2],int b[2][2],int c[2][2]);
main()
int a[2][2]={{3,3},{4,4}};
int b[2][2]={{1,1},{2,2}};
int c[2][2]={0},i,j;
matrix(a,b,c);
printf("product of 2 matrix is");
for(i=0;i<2;i++)
for(j=0;j<2;j++)
printf(" %d",c[i][j]);
printf(" ");
int row,col,sum1=0,sum2=0;
for(col=0;col<2;col++)
row=0;
sum1=(a[row][col]*b[row][col])+(a[row][col]*b[row+1][col]);
c[row][col]=sum1;
sum2=(a[row+1][col]*b[row][col])+(a[row+1][col]*b[row+1][col]);
c[row+1][col]=sum2;
Sep 10, 2009 | Intel Computers & Internet
Error Message V163
well col probably stands for color.....i would try unplugging your printer for 10 seconds then plugging it back in....that resets the printers memory. did you buy the right black ink cartridge? that might throw a error code.
Sep 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Home Logo
22 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
