Question about HEWLETT-PACKARD CM1415fnw AllInOne Laser Printer
Ghost image on a hp CM1415 - HEWLETT-PACKARD CM1415fnw AllInOne Laser Printer
  • HEWLETT-PACKARD Master
  • 1,121 Answers
Two reasons for ghost image
1. Toner cartridge faulty.
There is a part in toner cartridge called Drum cleaner (also called as tractor blade), if this part not clean the drum surface properly ghost image will form on drum & it will transfers on paper..
2. Fuser assm faulty.
There is a part in fuser assembly called Teflon sleeve. If toner particles deposited on teflon sleeve you may get ghost image..
Posted on Aug 21, 2014
LJ4200 ghosting in middle of page
Perform half test page & check for the ghost image.If half test page not showing ghost image go for 2. (Half test page:while printing open the door, take out the cartridge, remove inside paper gently) 1. check with another cartridge
2. replace teflon sleeve if available or replace fuser assembly..
Nov 29, 2012 | HP LaserJet 4200 Printer
Hp laserjet pro cm1415 fnw color mfp 51.23 error turn off then turn on
My printer displays a 51.23 error, what to do? hp laserjet pro cm 1415fn color mfp
Aug 24, 2012 | HP Office Equipment & Supplies
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
Ghost printing preceeding page images and or text
1.Most likely is the fuser assy, depending on what your page count is. 2.Could also be your toner cartridge especially if it is a reman
Dec 08, 2009 | HP LaserJet 4345mfp Printer
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
DELL DL-380 G5 "could not allocate page table memory" GSS 2.5
First of all, Dl380 is an hP product.
Secondly your ghost version seems a bit old as ghost 14 is the latest version. Having said that the problem could be at two ends.
1. At the ghost side where your version doesnot contain NIC drivers for PXE boot and HDD drivers for imaging. To fix this you can try manually adding the drivers to the network boot or floppy boot diskette.
You can get the drivers from HP website or the PSP CD that came with the server.
Alternatively you can upgrade to RDP instead of GHOST, RDP is Symantec's offering sold by HP for imaging it's servers.
2. There's some problem with your NIC settings or card if you are trying to PXE boot.
If you are using a floppy drive/ usb HDD, check from BIOS if it is detected.
Jun 25, 2009 | HP Compaq ProLiant DL380 G4 Server
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
HP 2600 ghosting
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
May 29, 2008 | HP Color LaserJet 2600n Printer
HEWLETT-PACKARD CM1415fnw AllInOne Laser Printer Logo
191 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
